I maintain an unofficial Debian package for peertube. I haven’t had any feedback so far, but it works on my end. If you get any issue with it, it should be quite straighforward to fix.
I will give here my opinion about packages for WebApp like Peertube (NodeJS), Mastodon or Diaspora (NodeJS, Ruby on Rails) or PHP applications like Nextcloud or Gnu.Social…
If it makes it easy to install server software, it’s not necessarily a good idea. What happens the day the package maintainer throws in the towel because managing dependencies becomes too complicated?
What to do in case of dependency conflicts between several applications on the same server?
It happened to me recently with Mastodon on FreeBSD. Finally starting from scratch, by installing the NodeJS dependencies at the application level and not the system (as I had done for Peertube Alpha) was much more training and allowed me to understand how to install Diaspora* !
Generally what is most complicated is what concerns the system administration: configuration of the web proxy server, configuration of the database, etc… And all this cannot be done with a package manager.
Peertube’s documentation is really well done: clear, precise, concise. I think it’s enough and it doesn’t necessarily require a package.
Juste for the record: it can be done with a good package. Like for the package phpmyadmin in Debian: it can setup the database and provides a configuration file for Apache (maybe nginx too?) that you just have to link in /etc/apache2/conf-enabled.
But creating such a package requires advanced knowledge of Debian tools, it’s not easy.
As PeerTube has a really good documentation and has an upgrade script that makes upgrades feel like a breeze, I would recommend the source installation instead of a community package. It allows to not depend on the package maintainer, and to be more reactive if a security version need to be deployed (package maintainers takes vacations too, for ex.). (warning: my opinion is kind of biased since I’m an old-fashioned sys-admin)
That being said, @rigelk is heavily in PT, so I think his packaging will be well maintained.
