8.1.5 transcoding issue
Hi all!
After upgrading peertube to the 8.1.5 from 7.2.3, when I upload a 1080p 5GB file, the transcoded file is still 5GB, while I were used (to save space):
upload the 5GB 1080p file, then after transcoding I keep the 1080p transcoded file which was much less, say 2-3GB, and deleting the original file.
How can I setup the parameters in order to keepthe previous behavior?
Edit: from 7.2.3 (not from 8.1.3)
7.2.3 example, original video is 1080p
Isn’t that if the original file meets HLS, it is not transcoded?
If that so, how I can force the transcoding anyways?
What you take a screen with 8.1.5 with the same input file?
I did reuploaded the same file with 8.1.5, when transcode ends I let you know it will take a while.
Issue confirmed, something is wrong.
3.3GB of transcoded 1080p file instead of the 1.7GB on 7.2.3
Edit: 7.2.3 not 8.1.4
Update: I checked upload times, the 1.7GB file was done on version 7.2.3 so it is possible the issue already were up after it.
I did upgraded from 7.2.3 to 8.1.4 on 4/4 15:07 (file was uploaded on 4/4 12:40) and then to 8.1.5 on april,16 11:19
Edited the previous messages to avoid version confusion. (note: will be nice to have the ~strikethrough~ for deleted text in forum markup :grinning_face:)
Transcoding completed also the 720p version
it is only a little more than the original transcode (861.8MB on 8.1.5 vs 837.9 on 7.2.3) but it is ok, the transcoding was done.
It seems if the original file has the same resolution of the transcode, it is skipped altogether, stripping only the audio.
I suggest creating an issue on GitHub - Chocobozzz/PeerTube: ActivityPub-federated video streaming platform using P2P directly in your web browser · GitHub so the admin can decide to disable quick transcoding completely.
Opened ticket 7565.
Thank you!
The GitHub issue is about a possible new option for admins, but I’m not sure whether I correctly understand the technical background.
We use the “PeerTube transcoding custom quality” plugin to render videos in high quality while keeping data usage manageable (CRF = 19).
As far as I know, videos used to be re-encoded in all formats. If someone uploaded a 1080p video in extremely high quality (which can mean 50 GB or more for one hour of footage), then when watching the video even in 1080p, only about 2 GB per hour would be transferred. Playback bandwidth was capped by the transcoded versions, which ensured that watching videos did not consume large amounts of data.
Am I correct in understanding that this is no longer the case in PeerTube 8.1.5?
Thanks,
Oliver
This is still the case if PeerTube considers the input file’s bandwidth to be too high. However, PeerTube considers the input file bitrate of @Bly to be acceptable. :slight_smile:
