Can't make Peertube work for me behind HAProxy
Hello, everyone. Please help - can’t make Peertube work. My plan is to have it working from behind HAProxy running on pFsense firewall. For that I set up a frontend listening on port 443 and redirecting requests to port 80 on an Ubuntu VM where Peertube is installed. I don’t have certbot on the VM and so, there are no locally issued and used SSL certificates.
From the netstat output I see that Nginx is listening on port 80 and Peertube is on port 9000
[root@u22 config 12:35 PM]$ netstat -tlpn
Active Internet connections (only servers)
Proto Recv-Q Send-Q Local Address           Foreign Address         State       PID/Program name
tcp        0      0 127.0.0.1:6379          0.0.0.0:*               LISTEN      654/redis-server 12
tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      4245/peertube
tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      628/systemd-resolve
tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      723/sshd: /usr/sbin
tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      4030/nginx: master
tcp        0      0 127.0.0.1:5432          0.0.0.0:*               LISTEN      868/postgres
tcp6       0      0 :::22                   :::*                    LISTEN      723/sshd: /usr/sbin
tcp6       0      0 :::80                   :::*                    LISTEN      4030/nginx: master
tcp6       0      0 ::1:6379                :::*                    LISTEN      654/redis-server 12
Journal output also shows no problems of any sort:
Dec 27 12:23:09 u22 systemd[1]: Started PeerTube daemon.
Dec 27 12:23:16 u22 peertube[4245]: [ptube.my-domain.com:443] 2024-12-27 12:23:16.406 info: Using following configuration file hierarchy: /var/www/peertube/config/default.yaml -> /var/www/peertube/config/production.yaml.
Dec 27 12:23:17 u22 peertube[4245]: [ptube.my-domain.com:443] 2024-12-27 12:23:17.141 info: Database peertube_prod is ready.
Dec 27 12:23:17 u22 peertube[4245]: [ptube.my-domain.com:443] 2024-12-27 12:23:17.733 info: Connecting to Redis in "standalone" mode...
Dec 27 12:23:17 u22 peertube[4245]: [ptube.my-domain.com:443] 2024-12-27 12:23:17.735 info: Using standalone redis options {
Dec 27 12:23:17 u22 peertube[4245]:   "db": 0,
Dec 27 12:23:17 u22 peertube[4245]:   "host": "127.0.0.1",
Dec 27 12:23:17 u22 peertube[4245]:   "port": 6379,
Dec 27 12:23:17 u22 peertube[4245]:   "path": null
Dec 27 12:23:17 u22 peertube[4245]: }
Dec 27 12:23:17 u22 peertube[4245]: [ptube.my-domain.com:443] 2024-12-27 12:23:17.743 info: Using imap.my-domain.com:587 as SMTP server.
Dec 27 12:23:17 u22 peertube[4245]: [ptube.my-domain.com:443] 2024-12-27 12:23:17.751 info: Testing SMTP server...
Dec 27 12:23:17 u22 peertube[4245]: [ptube.my-domain.com:443] 2024-12-27 12:23:17.865 info: Connected to redis.
Dec 27 12:23:18 u22 peertube[4245]: It is highly recommended to use a minimum Redis version of 6.2.0
Dec 27 12:23:18 u22 peertube[4245]:              Current: 6.0.16
Dec 27 12:23:18 u22 peertube[4245]: [ptube.my-domain.com:443] 2024-12-27 12:23:18.340 info: Connection established to 104.xxx.xxx.252:587 {
Dec 27 12:23:18 u22 peertube[4245]:   "component": "smtp-connection",
Dec 27 12:23:18 u22 peertube[4245]:   "sid": "GNjYwfiMnI",
Dec 27 12:23:18 u22 peertube[4245]:   "tnx": "network",
Dec 27 12:23:18 u22 peertube[4245]:   "localAddress": "192.168.20.63",
Dec 27 12:23:18 u22 peertube[4245]:   "localPort": 48026,
Dec 27 12:23:18 u22 peertube[4245]:   "remoteAddress": "104.xxx.xxx.252",
Dec 27 12:23:18 u22 peertube[4245]:   "remotePort": 587
Dec 27 12:23:18 u22 peertube[4245]: }
Dec 27 12:23:18 u22 peertube[4245]: [ptube.my-domain.com:443] 2024-12-27 12:23:18.433 info: Connection upgraded with STARTTLS {
Dec 27 12:23:18 u22 peertube[4245]:   "tnx": "smtp"
Dec 27 12:23:18 u22 peertube[4245]: [ptube.my-domain.com:443] 2024-12-27 12:23:18.652 info: User "myemail@my-domain.com" authenticated {
Dec 27 12:23:18 u22 peertube[4245]:   "tnx": "smtp",
Dec 27 12:23:18 u22 peertube[4245]:   "username": "myemail@my-domain.com",
Dec 27 12:23:18 u22 peertube[4245]:   "action": "authenticated",
Dec 27 12:23:18 u22 peertube[4245]:   "method": "PLAIN"
Dec 27 12:23:18 u22 peertube[4245]: [ptube.my-domain.com:443] 2024-12-27 12:23:18.654 info: Successfully connected to SMTP server.
Dec 27 12:23:18 u22 peertube[4245]: [ptube.my-domain.com:443] 2024-12-27 12:23:18.708 info: Connection closed {
Dec 27 12:23:18 u22 peertube[4245]: [ptube.my-domain.com:443] 2024-12-27 12:23:18.724 info: HTTP server listening on 127.0.0.1:9000
Dec 27 12:23:18 u22 peertube[4245]: [ptube.my-domain.com:443] 2024-12-27 12:23:18.724 info: Web server: https://ptube.my-domain.com
Dec 27 12:23:38 u22 peertube[4245]: [ptube.my-domain.com:443] 2024-12-27 12:23:38.377 info: 192.168.0.0 - - [27/Dec/2024:07:23:38 +0000] "GET / HTTP/1.0" 200 18481 "-" "Chrome"
Dec 27 12:23:40 u22 peertube[4245]: [ptube.my-domain.com:443] 2024-12-27 12:23:40.120 info: 192.168.0.0 - - [27/Dec/2024:07:23:40 +0000] "GET /client/assets/images/favicon.png?09eab1cf229d15d980cd0e59dc77adf47a3cb74e HTTP/1.0" 200 746 "https://ptube.my-domain.com/" "Chrome"
Dec 27 12:23:40 u22 peertube[4245]: [ptube.my-domain.com:443] 2024-12-27 12:23:40.143 info: 192.168.0.0 - - [27/Dec/2024:07:23:40 +0000] "GET /manifest.webmanifest?bb494f80b253d162ab5cd27fe823b5222d1b5fbb HTTP/1.0" 200 883 "https://ptube.my-domain.com/" "Chrome"
Dec 27 12:23:44 u22 peertube[4245]: [ptube.my-domain.com:443] 2024-12-27 12:23:44.257 info: 192.168.0.0 - - [27/Dec/2024:07:23:44 +0000] "GET / HTTP/1.0" 304 - "-" "Chrome"
Dec 27 12:23:45 u22 peertube[4245]: [ptube.my-domain.com:443] 2024-12-27 12:23:45.298 info: 192.168.20.254 - - [27/Dec/2024:07:23:45 +0000] "GET /client/assets/images/favicon.png?09eab1cf229d15d980cd0e59dc77adf47a3cb74e HTTP/1.0" 200 746 "-" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/130.0.0.0 Safari/537.36"
Dec 27 12:23:45 u22 peertube[4245]: [ptube.my-domain.com:443] 2024-12-27 12:23:45.397 info: 192.168.0.0 - - [27/Dec/2024:07:23:45 +0000] "GET /manifest.webmanifest?bb494f80b253d162ab5cd27fe823b5222d1b5fbb HTTP/1.0" 304 - "https://ptube.my-domain.com/" "Chrome"
Dec 27 12:24:35 u22 peertube[4245]: [ptube.my-domain.com:443] 2024-12-27 12:24:35.959 info: 192.168.0.0 - - [27/Dec/2024:07:24:35 +0000] "GET / HTTP/1.0" 304 - "-" "Chrome"
Dec 27 12:24:37 u22 peertube[4245]: [ptube.my-domain.com:443] 2024-12-27 12:24:37.840 info: 192.168.0.0 - - [27/Dec/2024:07:24:37 +0000] "GET /manifest.webmanifest?bb494f80b253d162ab5cd27fe823b5222d1b5fbb HTTP/1.0" 304 - "https://ptube.my-domain.com/" "Chrome"
As I am not using https on Nginx I had to completely comment the SSL server section in the Peertube Nginx configuration file and move all locations under the http (server {listen 80}). I had to comment location / { return 301 https://$host$request_uri; } location as it was causing too many redirects error.
When I try to access the site I get a blank page with Peertube favicon and a valid certificate. Nothing more than that. Am I doing something fundamentally wrong?
This is a fragment of the production.yaml I have in my config dir.
listen:
   2   hostname: '127.0.0.1'
   3   port: 9000
   4
   5 # Correspond to your reverse proxy server_name/listen configuration (i.e., your public PeerTube instance URL)
   6 webserver:
   7   https: True
   8   hostname: 'ptube.my-domain.com'
   9   port: 443
Thank you for any suggestion.
