J’ai mis en place une plateforme peertube avec un reverse proxy en utilisant l’option trust_proxy
Tout fonctionne bien sauf les /static/avatar et static/thumbnails
J’ai un not found et rien dans les logs
voici à quoi ressemble ma config nginx
server {
if ($host = peetube.tld) {
return 301 https://$host$request_uri;
} # managed by Certbot
listen 80;
server_name peetube.tld;
access_log /var/log/video.access.log;
error_log /var/log/video.error.log;
default_type "text/plain";
root /var/www/certbot;
server {
listen 443 ssl http2; # managed by Certbot
ssl_certificate /etc/letsencrypt/live/peetube.tld/fullchain.pem; # managed by Certbot
ssl_certificate_key /etc/letsencrypt/live/peetube.tld/privkey.pem; # managed by Certbot
include /etc/letsencrypt/options-ssl-nginx.conf; # managed by Certbot
ssl_dhparam /etc/letsencrypt/ssl-dhparams.pem; # managed by Certbot
# Configure with your resolvers
# resolver $DNS-IP-1 $DNS-IP-2 valid=300s;
# resolver_timeout 5s;
# Enable compression for JS/CSS/HTML bundle, for improved client load times.
# It might be nice to compress JSON, but leaving that out to protect against potential
# compression+encryption information leak attacks like BREACH.
gzip on;
gzip_types text/css text/html application/javascript;
gzip_vary on;
# Enable HSTS
# Tells browsers to stick with HTTPS and never visit the insecure HTTP
# version. Once a browser sees this header, it will only visit the site over
# HTTPS for the next 2 years: (read more on hstspreload.org)
#add_header Strict-Transport-Security "max-age=63072000; includeSubDomains";
# Bypass PeerTube for performance reasons. Could be removed
add_header 'Access-Control-Allow-Origin' '*';
add_header 'Access-Control-Allow-Methods' 'GET, OPTIONS';
add_header 'Access-Control-Allow-Headers' 'Range,DNT,X-CustomHeader,Keep-Alive,User-Agent,X-Requested-With,If-Modified-Since,Cache-Control,Content-Type';
add_header 'Access-Control-Max-Age' 1728000;
add_header 'Content-Type' 'text/plain charset=UTF-8';
add_header 'Content-Length' 0;
return 204;
# Cache 2 hours
add_header Cache-Control "public, max-age=7200";
rewrite ^/static/(thumbnails|avatars)/(.*)$ /$1/$2 break;
proxy_pass http://192.168.1.1:9000;
try_files $uri /;
location ~ ^/static/(webseed|redundancy)/ {
limit_rate 800k;
return 204;
access_log off;
rewrite ^/static/redundancy/(.*)$ /redundancy/$1 break;
try_files $uri /;
# Websocket tracker
location /tracker/socket {
# Don't close the websocket before this time
proxy_read_timeout 1200s;
proxy_set_header Connection "upgrade";
proxy_http_version 1.1;
proxy_set_header Host $host;
https://peertube.tld/static/thumbnails/dc3b74b6-9b97-4061-bb71-d32ad1549c50.jpg
me renvoi page introuvable
Merci de votre aide
