How do I switch off lazy load? According to the top line I have « 33 results on this instance » in the search results but only 10 show up and there is no way to load the rest. i have to make the browser window smaller, scroll down and then only then the rest gets loaded.
What is your web browser and screen resolution?
FF 130.0.1 (64-bit)
2560x1600
Can you share the URL where you have this bug?
Thanks, this page has been customized by the admin. It’s the reason why you have this scrolling bug. You can try to contact them
What part of the customisation is causing the issue?
I dont see any JS errors in the console.
"this page has been customized by the admin. It’s the reason why you have this scrolling bug. "
Is this based on anything real or just a wild shot in the dark?
