Hi, has anyone been able to install Mobilizon on the Raspberry Pi 3?
I’m having a hard time making Elixir work.
There shouldn’t be any special issues that I can think of. Feel free to post where you had trouble with things here or on our bug tracker.
You can try to use the Docker installation as well.
I finally made it, but it has been difficult. There are many issues that make me NOT recommend using a Raspberry Pi 3 to host Mobilizon. Some of them are:
- Elixir packages are broken on Ubuntu/Debian arm64, even upstream. I fixed that using Arch for arm, but I paid that with more time configuring the system.
- Yarn fails to build the frontend, because it goes out of memory. That needs to be compiled on another machine.
- Elixir often fails during compilation too. However setting mobilizon as a system service it restarts until it succeeds.
Once setup, it behaves nicely. I haven’t tested it with high traffic loads though.
