I see. Will add that configuration and check.
Yep. Deletion of video data from S3 works if minio is set in vhost style mode. Did setup a second tenant on minio test host with such config and it works now.
Also it seems that both modes does not work together as switching original instance to that one it did
break something for all the apps set to use path style access. Something to keep in mind.
@Chocobozzz Thank you for all the help with this issue.
