Upgrade to 5.1
Hello!
How to correct way to upgrade from 4.3 to 5.1?
I need upgrade to 5.0 with uses some upgrade scripts, or 5.1 version not need this?
Thank you!
I’m interested if you did the upgrade. I have a 4.1 instance that will be eventually upgraded.
As I understand, you need to look the change log and see if there are any changes needed to make manually and all that.
In any case, interested in your experience :slight_smile:
