Hi all.
Is there a way that I can grab the HLS stream instead of using the front end.
Pre-Req:
- Live stream, is always the same stream, as in the RTMP key
- OBS is used to stream to the Peertube instance.
Requirement:
Use the HLS stream to display on webpage.
Thanks
h
Actually, I was more after the directory where the streams would be saved. I use the same stream for all feeds as it is an always live feed…
I have not been able to get the api working… my bad… just a noob at these kind of things.
H
=== edit -====
got it working
now I am trying to find if there is any caching happening on the peertube… the feed does not seem to refresh in the screen I display…
Or if it is possible to delete the hls output after the stream is finished.
=========end edit=====
