I have a peertube instance and want to add Wasabi Storage to increase storage size.
I found this instructions but not sure if I understand how to use it correctly.
Do I need to call this mount
with root
If I call this mount --bind...
from non-peertube account the folders will be under that user and not peertube which means peertube will not be able to access them
Should I do this after each reboot (cronjob) ?
The instructions are bit confusing for me, if someone will elaborate a bit would be helpful
