Dear All Friends
Do you know how/where to add custom JavaScript code to PeerTube ?
I have tested to place on the Configuration/Advanced/Customization/Javascript and it’s not working well.
Could you help me ?
Thank you very much
Dear All Friends
Could you help me ?
Thank you very much
Anyone could answer this?
What do you mean by « it’s not working »?
A common mistake when doing so is to call your javascript to early, when the DOM in not initialized.
If you speak french, this topic was discussed here: Aide sur JS block dans configuration avancee
Depending of what you try to achieve, it could be simplier to develop a plugin:
When you develop a plugin, you have serveral helper function, so you can be sure your javascript is called at the right time.
Thank you very much John for your answer.
I’ll try learn this first before back to you again (if you don’t mind).
I’ll using google translate to learn it
