I hope, that’s ok that I write in english. If not, I will try to repeat my question in french. But remember: My french is like hell.
I want to add a Navigation Bar and a Footer to Framadate, if possible with Bootstrap Framework.
I recognized that Framadate is using the Smarty Template Engine. Do I have to change the original Code or add additional Smarty Templates? That wouldn’t be the preferred solution for me as I want to use the Navigation Bar and Footer for other services too.
I have tried with an iframe but there occured some problems like duplicated iframes when clicking the “Home”-Link.
How did you do that on your demo site of Framadate? What concepts are there for embedding framadate?
Merci pour l’aide
Papillon
