Advice? Docker, nginx & reverse proxies
Hi all,
I’m not very experienced, so would really appreciate your advice on my nginx setup. Is it safe, or do you think it will lead to performance issues/errors?
I tried to use the default nginx config included in the docker volume
(docker-compose.yaml version: 3.3). I think this didn’t work because:
  • I am running several applications and subdomains on the same VPS
  • Using a nginx reverse proxy config
  • The only way I could get SSL working is by putting the cert in the http block in nginx.conf, with server blocks inside it
I tried adding in what was in the default peertube nginx file line-by-line. But the below is the only thing that works for me:
server {
    listen              443 ssl;
    server_name         subdomain.example.org;
error_log  /var/log/nginx/peertube.error.log;
      location / {
       proxy_set_header Host $host;
       proxy_set_header X-Forwarded-Host $host;
       proxy_set_header X-Forwarded-Server $host;
       proxy_set_header X-Forwarded-Proto $scheme;
	   proxy_set_header X-Forwarded-For
	   $proxy_add_x_forwarded_for;
       proxy_http_version 1.1;
       proxy_set_header Connection $connection_upgrade;
       proxy_pass http://127.0.0.1:9000;
      client_max_body_size 2G;
# additional settings below this, in the http block:
    sendfile on;
    tcp_nopush on;
    types_hash_max_size 2048;
    gzip on;
