Authentication occurs every half hour
Hello, I’ve been massively editing video categories for a couple of days(I won’t learn anything about the API)), and I noticed that I was thrown out almost every half hour. It’s hard to say what this is due to, I open for editing for example 10 videos(one at a time), but 10 tabs are just loaded. Here’s what I get in the logs and here’s what I see in the settings. Maybe I don’t understand something. Thanks
oauth2:
  token_lifetime:
    access_token: '1 day'
    refresh_token: '2 weeks'
warn[1/5/2025, 7:20:01 PM] Login error
  "err": {
    "stack": "invalid_grant: Invalid grant: refresh token is invalid\n    at handleRefreshGrant (file:///var/www/peertube/versions/peertube-v7.0.0/dist/core/lib/auth/oauth.js:132:15)\n    at process.processTicksAndRejections (node:internal/process/task_queues:95:5)\n    at async handleToken (file:///var/www/peertube/versions/peertube-v7.0.0/dist/core/controllers/api/users/token.js:32:23)",
    "message": "Invalid grant: refresh token is invalid",
    "statusCode": 400,
    "status": 400,
    "code": 400,
    "name": "invalid_grant"
error[1/5/2025, 7:20:01 PM] Client log: You need to reconnect
  "tags": [
    "client"
  "userAgent": "Mozilla/5.0 (X11; Linux x86_64; rv:133.0) Gecko/20100101 Firefox/133.0",
  "stackTrace": "You need to reconnect\nrefreshAccessToken/this.refreshingTokenObservable</<@https://angeltales.angellive.ru/client/ru-RU/chunk-X3RCWQ3R.js:21:46200\nn@https://angeltales.angellive.ru/client/ru-RU/chunk-X3RCWQ3R.js:11:21397\n_trySubscribe@https://angeltales.angellive.ru/client/ru-RU/chunk-X3RCWQ3R.js:11:4521\nsubscribe/z<@https://angeltales.angellive.ru/client/ru-RU/chunk-X3RCWQ3R.js:11:4464\nGi@https://angeltales.angellive.ru/client/ru-RU/chunk-X3RCWQ3R.js:11:2267\nsubscribe@https://angeltales.angellive.ru/client/ru-RU/chunk-X3RCWQ3R.js:11:4382\nue/</n<@https://angeltales.angellive.ru/client/ru-RU/chunk-X3RCWQ3R.js:11:26283\nRh/this._error<@https://angeltales.angellive.ru/client/ru-RU/chunk-X3RCWQ3R.js:11:7753\nerror@https://angeltales.angellive.ru/client/ru-RU/chunk-X3RCWQ3R.js:11:2652\nOe/</<@https://angeltales.angellive.ru/client/ru-RU/chunk-X3RCWQ3R.js:11:30053\nRh/this._error<@https://angeltales.angellive.ru/client/ru-RU/chunk-X3RCWQ3R.js:11:7753\nerror@https://angeltales.angellive.ru/client/ru-RU/chunk-X3RCWQ3R.js:11:2652\n_error@https://angeltales.angellive.ru/client/ru-RU/chunk-X3RCWQ3R.js:11:2896\nerror@https://angeltales.angellive.ru/client/ru-RU/chunk-X3RCWQ3R.js:11:2652\n_error@https://angeltales.angellive.ru/client/ru-RU/chunk-X3RCWQ3R.js:11:2896\nerror@https://angeltales.angellive.ru/client/ru-RU/chunk-X3RCWQ3R.js:11:2652\n_error@https://angeltales.angellive.ru/client/ru-RU/chunk-X3RCWQ3R.js:11:2896\nerror@https://angeltales.angellive.ru/client/ru-RU/chunk-X3RCWQ3R.js:11:2652\n_error@https://angeltales.angellive.ru/client/ru-RU/chunk-X3RCWQ3R.js:11:2896\nerror@https://angeltales.angellive.ru/client/ru-RU/chunk-X3RCWQ3R.js:11:2652\nOe/</<@https://angeltales.angellive.ru/client/ru-RU/chunk-X3RCWQ3R.js:11:30053\nRh/this._error<@https://angeltales.angellive.ru/client/ru-RU/chunk-X3RCWQ3R.js:11:7753\nerror@https://angeltales.angellive.ru/client/ru-RU/chunk-X3RCWQ3R.js:11:2652\nn@https://angeltales.angellive.ru/client/ru-RU/chunk-X3RCWQ3R.js:11:21391\n_trySubscribe@https://angeltales.angellive.ru/client/ru-RU/chunk-X3RCWQ3R.js:11:4521\nsubscribe/z<@https://angeltales.angellive.ru/client/ru-RU/chunk-X3RCWQ3R.js:11:4464\nGi@https://angeltales.angellive.ru/client/ru-RU/chunk-X3RCWQ3R.js:11:2267\nsubscribe@https://angeltales.angellive.ru/client/ru-RU/chunk-X3RCWQ3R.js:11:4382\nue/</n<@https://angeltales.angellive.ru/client/ru-RU/chunk-X3RCWQ3R.js:11:26283\nRh/this._error<@https://angeltales.angellive.ru/client/ru-RU/chunk-X3RCWQ3R.js:11:7753\nerror@https://angeltales.angellive.ru/client/ru-RU/chunk-X3RCWQ3R.js:11:2652\n_error@https://angeltales.angellive.ru/client/ru-RU/chunk-X3RCWQ3R.js:11:2896\nerror@https://angeltales.angellive.ru/client/ru-RU/chunk-X3RCWQ3R.js:11:2652\nf@https://angeltales.angellive.ru/client/ru-RU/chunk-X3RCWQ3R.js:16:16435\ninvokeTask@https://angeltales.angellive.ru/client/ru-RU/polyfills-RM43TNSZ.js:1:122301\nonInvokeTask@https://angeltales.angellive.ru/client/ru-RU/chunk-X3RCWQ3R.js:15:30548\ninvokeTask@https://angeltales.angellive.ru/client/ru-RU/polyfills-RM43TNSZ.js:1:122222\nrunTask@https://angeltales.angellive.ru/client/ru-RU/polyfills-RM43TNSZ.js:1:117550\ninvokeTask@https://angeltales.angellive.ru/client/ru-RU/polyfills-RM43TNSZ.js:1:123382\ny@https://angeltales.angellive.ru/client/ru-RU/polyfills-RM43TNSZ.js:1:130518\nH@https://angeltales.angellive.ru/client/ru-RU/polyfills-RM43TNSZ.js:1:130918\nq@https://angeltales.angellive.ru/client/ru-RU/polyfills-RM43TNSZ.js:1:131080\n",
  "url": "https://angeltales.angellive.ru/w/p/9TLyEtM8X3NV5DuXeGqeey?playlistPosition=132&resume=true"
error[1/5/2025, 7:20:02 PM] Client log: You need to reconnect
  "tags": [
    "client"
  "stackTrace": "You need to reconnect\nrefreshAccessToken/<@https://angeltales.angellive.ru/client/ru-RU/chunk-X3RCWQ3R.js:21:45525\nn@https://angeltales.angellive.ru/client/ru-RU/chunk-X3RCWQ3R.js:11:21397\n_trySubscribe@https://angeltales.angellive.ru/client/ru-RU/chunk-X3RCWQ3R.js:11:4521\nsubscribe/z<@https://angeltales.angellive.ru/client/ru-RU/chunk-X3RCWQ3R.js:11:4464\nGi@https://angeltales.angellive.ru/client/ru-RU/chunk-X3RCWQ3R.js:11:2267\nsubscribe@https://angeltales.angellive.ru/client/ru-RU/chunk-X3RCWQ3R.js:11:4382\nPe/<@https://angeltales.angellive.ru/client/ru-RU/chunk-X3RCWQ3R.js:11:16047\nF/</<@https://angeltales.angellive.ru/client/ru-RU/chunk-X3RCWQ3R.js:11:7400\nsubscribe/z<@https://angeltales.angellive.ru/client/ru-RU/chunk-X3RCWQ3R.js:11:4428\nGi@https://angeltales.angellive.ru/client/ru-RU/chunk-X3RCWQ3R.js:11:2267\nsubscribe@https://angeltales.angellive.ru/client/ru-RU/chunk-X3RCWQ3R.js:11:4382\nue/</n<@https://angeltales.angellive.ru/client/ru-RU/chunk-X3RCWQ3R.js:11:26283\nRh/this._error<@https://angeltales.angellive.ru/client/ru-RU/chunk-X3RCWQ3R.js:11:7753\nerror@https://angeltales.angellive.ru/client/ru-RU/chunk-X3RCWQ3R.js:11:2652\n_error@https://angeltales.angellive.ru/client/ru-RU/chunk-X3RCWQ3R.js:11:2896\nerror@https://angeltales.angellive.ru/client/ru-RU/chunk-X3RCWQ3R.js:11:2652\nf@https://angeltales.angellive.ru/client/ru-RU/chunk-X3RCWQ3R.js:16:16435\ninvokeTask@https://angeltales.angellive.ru/client/ru-RU/polyfills-RM43TNSZ.js:1:122301\nonInvokeTask@https://angeltales.angellive.ru/client/ru-RU/chunk-X3RCWQ3R.js:15:30548\ninvokeTask@https://angeltales.angellive.ru/client/ru-RU/polyfills-RM43TNSZ.js:1:122222\nrunTask@https://angeltales.angellive.ru/client/ru-RU/polyfills-RM43TNSZ.js:1:117550\ninvokeTask@https://angeltales.angellive.ru/client/ru-RU/polyfills-RM43TNSZ.js:1:123382\ny@https://angeltales.angellive.ru/client/ru-RU/polyfills-RM43TNSZ.js:1:130518\nH@https://angeltales.angellive.ru/client/ru-RU/polyfills-RM43TNSZ.js:1:130918\nq@https://angeltales.angellive.ru/client/ru-RU/polyfills-RM43TNSZ.js:1:131080\n",
error[1/5/2025, 7:26:43 PM] Client log: Backend returned code 0, errorMessage is: Неизвестная ошибка сервера
  "tags": [
    "client"
  "username": "angellive",
  "meta": "{\"url\":\"https://angeltales.angellive.ru/api/v1/videos/b80a30e3-0e40-4fbb-a3d2-fee037bfee1c/token\"}",
  "url": "https://angeltales.angellive.ru/w/p/9TLyEtM8X3NV5DuXeGqeey?playlistPosition=140&resume=true"
warn[1/5/2025, 7:54:15 PM] Login error
  "err": {
    "statusCode": 400,
    "status": 400,
    "code": 400,
error[1/5/2025, 7:54:18 PM] Client log: You need to reconnect
  "tags": [
    "client"
  "url": "https://angeltales.angellive.ru/my-library/video-playlists/9TLyEtM8X3NV5DuXeGqeey"
  "tags": [
    "client"
error[1/5/2025, 7:54:19 PM] Client log: You need to reconnect
  "tags": [
    "client"
warn[1/5/2025, 8:27:36 PM] Login error
  "err": {
    "statusCode": 400,
    "status": 400,
    "code": 400,
error[1/5/2025, 8:27:36 PM] Client log: You need to reconnect
  "tags": [
    "client"
  "url": "https://angeltales.angellive.ru/my-library/video-playlists"
  "tags": [
    "client"
Now it’s thrown out 2 times in a row, the IP hasn’t changed, but it’s throwing out
error[1/6/2025, 8:08:40 PM] Client log: Backend returned code 0, errorMessage is: Unknown server error
  "tags": [
    "client"
  "meta": "{\"url\":\"https://angeltales.angellive.ru/api/v1/videos/386\"}",
  "url": "https://angeltales.angellive.ru/videos/update/873wiGvsFHCDqGKeS9MawG"
error[1/6/2025, 8:08:40 PM] Client log: Ошибка: Unknown server error
  "tags": [
    "client"
error[1/6/2025, 8:27:53 PM] Client log: HLS.js error: networkError - fatal: true - levelLoadError
  "tags": [
    "client"
  "url": "https://angeltales.angellive.ru/w/eDqQxCicU8od1wGVemBZSx"
warn[1/6/2025, 8:28:26 PM] Login error
  "err": {
    "statusCode": 400,
    "status": 400,
    "code": 400,
error[1/6/2025, 8:28:26 PM] Client log: You need to reconnect
  "tags": [
    "client"
  "url": "https://angeltales.angellive.ru/w/vZg5LbovuCpMVD5E5PyDws"
  "tags": [
    "client"
warn[1/6/2025, 8:29:13 PM] Login error
  "err": {
    "statusCode": 400,
    "status": 400,
    "code": 400,
error[1/6/2025, 8:29:13 PM] Client log: You need to reconnect
  "tags": [
    "client"
  "url": "https://angeltales.angellive.ru/w/uk1dAfEctSfE77bpePLFfK"
  "tags": [
    "client"
Nginx
213.108.6.232 - - [06/Jan/2025:23:30:06 +0300] "GET /api/v1/plugins/peertube-plugin-simplelogo/public-settings HTTP/2.0" 304 0 "https://angeltales.angellive.ru/videos/browse" "Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:133.0) Gecko/20100101 Firefox/133.0"
213.108.6.232 - - [06/Jan/2025:23:30:06 +0300] "GET /api/v1/oauth-clients/local HTTP/2.0" 304 0 "https://angeltales.angellive.ru/videos/browse" "Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:133.0) Gecko/20100101 Firefox/133.0"
213.108.6.232 - - [06/Jan/2025:23:30:06 +0300] "GET /api/v1/config/ HTTP/2.0" 304 0 "https://angeltales.angellive.ru/videos/browse" "Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:133.0) Gecko/20100101 Firefox/133.0"
213.108.6.232 - - [06/Jan/2025:23:30:06 +0300] "GET /api/v1/users/me HTTP/2.0" 304 0 "https://angeltales.angellive.ru/videos/browse" "Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:133.0) Gecko/20100101 Firefox/133.0"
213.108.6.232 - - [06/Jan/2025:23:30:06 +0300] "GET /api/v1/users/me/notifications?start=0&count=0&unread=true HTTP/2.0" 304 0 "https://angeltales.angellive.ru/videos/browse" "Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:133.0) Gecko/20100101 Firefox/133.0"
213.108.6.232 - - [06/Jan/2025:23:30:06 +0300] "GET /client/ru-RU/chunk-7V7TWLNV.js HTTP/2.0" 200 1988 "https://angeltales.angellive.ru/client/ru-RU/main-K7PBERES.js" "Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:133.0) Gecko/20100101 Firefox/133.0"
213.108.6.232 - - [06/Jan/2025:23:30:07 +0300] "GET /api/v1/server/following?start=0&count=1&state=accepted HTTP/2.0" 200 21 "https://angeltales.angellive.ru/videos/browse" "Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:133.0) Gecko/20100101 Firefox/133.0"
213.108.6.232 - - [06/Jan/2025:23:30:07 +0300] "GET /api/v1/videos/categories HTTP/2.0" 304 0 "https://angeltales.angellive.ru/videos/browse" "Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:133.0) Gecko/20100101 Firefox/133.0"
213.108.6.232 - - [06/Jan/2025:23:30:07 +0300] "GET /api/v1/videos/languages HTTP/2.0" 304 0 "https://angeltales.angellive.ru/videos/browse" "Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:133.0) Gecko/20100101 Firefox/133.0"
213.108.6.232 - - [06/Jan/2025:23:30:07 +0300] "GET /api/v1/config/about HTTP/2.0" 304 0 "https://angeltales.angellive.ru/videos/browse" "Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:133.0) Gecko/20100101 Firefox/133.0"
213.108.6.232 - - [06/Jan/2025:23:30:07 +0300] "GET /api/v1/config/about HTTP/2.0" 200 1854 "https://angeltales.angellive.ru/videos/browse" "Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:133.0) Gecko/20100101 Firefox/133.0"
213.108.6.232 - - [06/Jan/2025:23:30:07 +0300] "GET /api/v1/videos?start=0&count=25&sort=-publishedAt&skipCount=true&isLive=true&nsfw=both&languageOneOf=ru HTTP/2.0" 200 11 "https://angeltales.angellive.ru/videos/browse?languageOneOf=ru&s=2" "Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:133.0) Gecko/20100101 Firefox/133.0"
213.108.6.232 - - [06/Jan/2025:23:30:07 +0300] "GET /socket.io/?accessToken=3df753076d358a135ee71b755a2618d7e085b1c8&EIO=4&transport=polling&t=hx2eqbf8 HTTP/2.0" 200 118 "https://angeltales.angellive.ru/videos/browse?languageOneOf=ru&s=2" "Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:133.0) Gecko/20100101 Firefox/133.0"
213.108.6.232 - - [06/Jan/2025:23:30:07 +0300] "GET /api/v1/videos?start=0&count=25&sort=-publishedAt&skipCount=true&isLive=false&nsfw=both&languageOneOf=ru HTTP/2.0" 200 81336 "https://angeltales.angellive.ru/videos/browse?languageOneOf=ru&s=2" "Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:133.0) Gecko/20100101 Firefox/133.0"
213.108.6.232 - - [06/Jan/2025:23:30:07 +0300] "POST /socket.io/?accessToken=3df753076d358a135ee71b755a2618d7e085b1c8&EIO=4&transport=polling&t=hx2h167o&sid=SVhPYC5UJFS-5CewAASB HTTP/2.0" 200 2 "https://angeltales.angellive.ru/videos/browse?languageOneOf=ru&s=2" "Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:133.0) Gecko/20100101 Firefox/133.0"
213.108.6.232 - - [06/Jan/2025:23:30:07 +0300] "GET /socket.io/?accessToken=3df753076d358a135ee71b755a2618d7e085b1c8&EIO=4&transport=polling&t=hx2h1bcb&sid=SVhPYC5UJFS-5CewAASB HTTP/2.0" 200 52 "https://angeltales.angellive.ru/videos/browse?languageOneOf=ru&s=2" "Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:133.0) Gecko/20100101 Firefox/133.0"
