Automatic captions artifacts
On CoMaps How to make a community based map navigation app based on OpenStreetMap - peertube.openstreetmap.fr , the automatic transcription turns Welsh (the speech remains in English) at 29:39.
And in the French translation of these captions, the entire text corresponding to the Welsh text, is entirely fabricated. For example, the text « Can you say something about the language, is it objective C, is it Swift, is it easy to build, that sort of thing » has ended up in the French captions as « Qu’est-ce que le temps ? Est-il un concept absolu ou relatif ? Dans la science, est-il absolu ou relatif ? » which means « What is time? Is it an absolute or relative concept? In science, is it absolute or relative? ». A similar thing happened in all the other 4 videos from this conference that I sampled ( https[://]peertube[.]openstreetmap[.]fr/w/05596101-d5be-4052-98a1-df51e853badb at 26:19; https[://]peertube[.]openstreetmap[.]fr/w/513f06c0-0855-4242-a697-ed96cff77714 at 18:39 and 22:33, and https[://]peertube[.]openstreetmap[.]fr/w/513f06c0-0855-4242-a697-ed96cff77714 at 22:39)
It would be good if PeerTube automatically detected the non-English (or obvious random statistical nonsense from the training data) transcription, and flagged it to the video owner for review. At that point, they could either confirm it (and so the translation proceeds in e.g. Welsh-French mode, not English-French, for that phrase), or manually correct the captioning.
This is a fairly obvious accessibility issue for both language barriers and hearing/auditory processing difficulties. (although obviously this is a FOSS project and I don’t expect a professional support!)
Other than this occasional issue, I found the captioning really good, thanks!
I’m sorry but I’m not sure to understand. PeerTube doesn’t support transcription in other languages so I don’t know how you’ve generated the French captions?
