Hello all i am using peertube using docker and i am backing up my peertube using Restic
i have tested it and it works great but the problem is i am also backing up Postgresql files without creating a dump of it
the reason i do that is because i do not know how i should proceed with it
for now this is how i use it to backup my peertube
version: "3.3"
services:
backup:
image: mazzolino/restic
hostname: docker
environment:
RUN_ON_STARTUP: "true"
BACKUP_CRON: "*/30 * * * *"
RESTIC_REPOSITORY: b2:dockervolumes:/
RESTIC_PASSWORD: "${RESTIC_PASSWORD}"
RESTIC_BACKUP_SOURCES: /var/lib/docker/volumes
RESTIC_BACKUP_ARGS: >-
--tag docker-volumes
--exclude=/var/lib/docker/volumes/peertube-peertube-data/_data/logs
--verbose
RESTIC_FORGET_ARGS: >-
--keep-last 2
--keep-daily 3
B2_ACCOUNT_ID: "${RESTIC_B2_ACCOUNT_ID}"
B2_ACCOUNT_KEY: "${RESTIC_B2_ACCOUNT_KEY}"
TZ: Europe/Brussels
volumes:
# Peertube
- /var/lib/docker/volumes/peertube-db-data:/var/lib/docker/volumes/peertube-db-data # PostgreSQL
- /var/lib/docker/volumes/peertube-redis-data:/var/lib/docker/volumes/peertube-redis-data #Redis
- /var/lib/docker/volumes/peertube-peertube-data:/var/lib/docker/volumes/peertube-peertube-data # Full Data
- /var/lib/docker/volumes/peertube-peertube-config:/var/lib/docker/volumes/peertube-peertube-config #Config
prune:
hostname: docker
environment:
PRUNE_CRON: "0 * * * *"
RESTIC_REPOSITORY: b2:dockervolumes:/restic
TZ: Europe/Brussels
is it fine to just backup the raw postgresql files without creating a dump ?
i have tested it and it works fine but i am not sure
