I’d like to update the configuration of my Peertube instance (3.1.0 - Docker) through admin interface, unfortunately, I get error message when I click on « Update configuration »:
Should have a valid torrents cache size.
Should have a valid transcoding concurrency number.
Should have a valid transcoding 1440p resolution enabled boolean.
Should have a valid import concurrency number.
Should have a valid default trending algorithm.
Should have a valid array of enabled trending algorithms.
Don’t know where to update these settings as instance looks running well.
Yes, production.yaml and local-production.json. local-production.json overrides production.yaml and production.yaml overrides default.yaml. But I don’t understand why your configuration is invalid, since non existing keys should default to the one in default.yaml.
Okay I think I understand. Did you use -v option with docker-compose down when your upgraded peertube? See https://docs.joinpeertube.org/install-docker?id=upgrade. If no, the client build is still in old peertube version
