So I’ve set up 2 peertube v7 instances, with different domain names.
Each one works and is accessible on the web, but I cannot get them to follow one another.
My goal is to add redundancy to video hosting.
- We have one instance which is normally used, which possesses videos.
- The other is empty (no video)
- I want to make the empty one to follow the one with videos (kind of a master-slave behavior ?)
When making the follower request from the slave, this is what I get on the master :
[peertube.tata.casa:443] 2025-01-03 07:45:06.200 info: Fetching remote actor https://peertube.alt.tata.casa/accounts/peertube.
[peertube.tata.casa:443] 2025-01-03 07:45:09.458 warn: Error in ActivityPub signature checker. {
"err": {
"stack": "RequestError: cacheableLookup ENOTFOUND peertube.alt.tata.casa\n at ClientRequest.<anonymous> (file:///app/node_modules/got/dist/source/core/index.js:792:107)\n at Object.onceWrapper (node:events:632:26)\n at ClientRequest.emit (node:events:529:35)\n at TLSSocket.socketErrorListener (node:_http_client:501:9)\n at TLSSocket.emit (node:events:517:28)\n at emitErrorNT (node:internal/streams/destroy:151:8)\n at emitErrorCloseNT (node:internal/streams/destroy:116:3)\n at process.processTicksAndRejections (node:internal/process/task_queues:82:21)\n at CacheableLookup.lookupAsync (file:///app/node_modules/cacheable-lookup/source/index.js:202:18)",
"message": "cacheableLookup ENOTFOUND peertube.alt.tata.casa",
"name": "RequestError",
"requestHeaders": {
"user-agent": "PeerTube/7.0.0 (+https://peertube.tata.casa)",
"date": "Fri, 03 Jan 2025 07:45:06 GMT",
"accept": "application/activity+json, application/ld+json",
"accept-encoding": "gzip, deflate, br",
"host": "peertube.alt.tata.casa",
"signature": "keyId=\"https://peertube.tata.casa/accounts/peertube\",algorithm=\"rsa-sha256\",headers=\"(request-target) host date\",signature=\"fPCoqINsPvdOHSpy7rRWf9SNY53msocqKr51so4TQ+JTS26vQ4HCQC+CpBAG3fQPDjR+uxQA62kc3rGY765ePagQqklNN90l4AtVWtrjpBTQbo0/hD9ZaLrGr8fG/H8cx+qXCyNA/5ooxzoqa1PheXAhCmMGGfbjQr4l+EivYjCj3DXs/mlgwoTzVl1WtMoZpdcPVzj6Zc4acJD0U1RJ6p844VUWiNlgpJ6aI2Gobwrrq7B+iUWqqgKeJyXa/WSdM5YGiNad+Qf6IfXgHmSVuj5VcZ4kA1GCUnBexyA84duQo0HC0+JPHuCGJCTzrv+0Gr62gy3CP2gm40dSEKZwfA==\""
"requestUrl": "https://peertube.alt.tata.casa/accounts/peertube",
"requestMethod": "GET"
[peertube.tata.casa:443] 2025-01-03 07:45:09.465 info: 37.65.43.141 - - [03/Jan/2025:07:45:09 +0000] "POST /accounts/peertube/inbox HTTP/1.1" 403 109 "-" "PeerTube/7.0.0 (+https://peertube.alt.tata.casa)"
And this is what I get on the slave :
[peertube.alt.tata.casa:443] 2025-01-03 07:44:52.503 info: 2a02:: - - [03/Jan/2025:07:44:52 +0000] "POST /api/v1/server/following HTTP/1.1" 204 - "https://peertube.alt.tata.casa/admin/settings/follows/following-list" "Firefox"
[peertube.alt.tata.casa:443] 2025-01-03 07:44:52.519 info: Processing ActivityPub follow in job 3.
[peertube.alt.tata.casa:443] 2025-01-03 07:44:53.233 info: Creating job to send follow request to https://peertube.tata.casa/accounts/peertube.
[peertube.alt.tata.casa:443] 2025-01-03 07:44:53.323 info: Processing ActivityPub unicast in job 2.
[peertube.alt.tata.casa:443] 2025-01-03 07:45:09.461 info: Updating 0 good actor follows and 1 bad actor follows scores in cache. {
"badInboxes": [
"https://peertube.tata.casa/accounts/peertube/inbox"
[peertube.alt.tata.casa:443] 2025-01-03 07:46:13.065 info: 2a02:: - - [03/Jan/2025:07:46:13 +0000] "GET /admin/settings/follows/following-list HTTP/1.1" 200 18859 "-" "Firefox"
Result :
The request appears on the web-view from the slave.
No request appears on the master. Thus I cannot reply to associate the two instances.
All in all, I find no information on this case in the doc, or on what is a « badInbox »'.
I should probably say that I previously changed the domain name of the master, from alt to « without alt ». (ie the slave has the previous address the master had, and the master changed to get the « main domain »). The slave was started cleanly, never changed its domain. The master, I used the script given in the doc.
The two instances are using the official docker images.
The migration script was correctly executed on master, which was previously a 6.0.1.
Thank you for your help.
