Hi i havea new peertube and user on my platform cannot get a comment or a abo for the channels or videos ! how can i activate this ?
so users cannot comment on my local videos, the users are regisred on the server.
Have you enabled comments in video properties?
yes, thats my platform tv1.gomntu.space
and users cannot follow a channel
You have a theme or a plugin that hides these buttons.
Here is an sample of your instance’s CSS:
.video-actions[_ngcontent-xby-c167] .action-button:after {
display:none
This hide most of the action buttons.
And don’t know which theme or plugin is responsible, it seems you have a lot of them installed.
ah ok i will try this, but yes i have installed 5 themes , so i will remove them and come back to the default theme,
how can i enable the default theme again ? i have removed all but in the theme option i nothing, i cannot save the config.
NOW, i have removed all plugins and themes, and the comment section and abo button shows again
i have to figure out witch plugin are so stupit to disable the abo and comment section.
But there is one thing, i have no theme installed and cannot save the server config:
