Je viens d’initialiser un projet Jhipster sur un dépôt framagit et en voulant configurer une CI avec un stage build j’ai un permission denied sur la commande ./mvnw compile qui fonctionne bien en local.
Voici mon fichier de conf :
image: jhipster/jhipster:v7.0.1
cache:
key: '$CI_COMMIT_REF_NAME'
paths:
- .maven/
stages:
- check
- build
- test
- package
- release
- deploy
before_script:
- export NG_CLI_ANALYTICS="false"
- export MAVEN_USER_HOME=`pwd`/.maven
nohttp:
stage: check
script:
- ./mvnw -ntp checkstyle:check -Dmaven.repo.local=$MAVEN_USER_HOME
maven-compile:
stage: build
script:
- ./mvnw -ntp compile -P-webapp -Dmaven.repo.local=$MAVEN_USER_HOME
artifacts:
paths:
- target/classes/
- target/generated-sources/
expire_in: 1 day
maven-test:
# DinD service is required for Testcontainers
services:
- docker:dind
variables:
# Instruct Testcontainers to use the daemon of DinD.
DOCKER_HOST: 'tcp://docker:2375'
# Improve performance with overlayfs.
DOCKER_DRIVER: overlay2
stage: test
script:
- ./mvnw -ntp verify -P-webapp -Dmaven.repo.local=$MAVEN_USER_HOME -Dspring.profiles.active=testcontainers
artifacts:
reports:
junit:
- target/surefire-reports/TEST-*.xml
- target/failsafe-reports/TEST-*.xml
paths:
- target/site
expire_in: 1 day
frontend-test:
stage: test
script:
- npm install
- npm test
artifacts:
reports:
junit: target/test-results/TESTS-results-jest.xml
paths:
- target/test-results
- target/jacoco
expire_in: 1 day
maven-package:
stage: package
script:
- ./mvnw -ntp verify -Pprod -DskipTests -Dmaven.repo.local=$MAVEN_USER_HOME
artifacts:
paths:
- target/*.jar
- target/classes
expire_in: 1 day
Est-ce que vous auriez une idée de ce qui ce passe ? ![]()
Merci d’avance.
