Merci pour ces explications et cette référence ! Donc je peux rajouter à mon fichier config.exs une ligne comme celle ci-dessous ?
config, mobilizon, :extra_categories,
%{id: :danse, label: "Danse"}
Mais est-ce que je dois aussi ajouter aussi les autres par défaut (qui semblent déjà présente) ??
Voici à quoi ressemble mon fichier actuel
# Mobilizon instance configuration
import Config
config :mobilizon, Mobilizon.Web.Endpoint,
server: true,
url: [host: "mobilizon.mydomain.tld"],
http: [
ip: {127,0,0,1},
port: 8095
secret_key_base: "xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx"
config :mobilizon, Mobilizon.Web.Auth.Guardian,
secret_key: "xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx"
config :mobilizon, :instance,
name: "Mobilizon Monassociation",
description: "Pour vos événements ! Mobilizon Monassociation est l'instance Mobilizon de Monassociation chez nous !",
hostname: "mobilizon.mydomain.tld",
registrations_open: true,
demo: false,
remove_orphan_uploads: true,
orphan_upload_grace_period_hours: 48,
remove_unconfirmed_users: true,
unconfirmed_user_grace_period_hours: 48,
activity_expire_days: 365,
activity_keep_number: 100,
enable_instance_feeds: true,
allow_relay: true,
federating: true,
email_from: "mobilizon@mobilizon.mydomain.tld",
email_reply_to: "mobilizon@mobilizon.mydomain.tld"
config :mobilizon, Mobilizon.Storage.Repo,
adapter: Ecto.Adapters.Postgres,
username: "mobilizon",
password: "xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx",
database: "mobilizon",
hostname: "localhost",
port: "5432",
pool_size: 10
config :mobilizon, Mobilizon.Service.Auth.LDAPAuthenticator, Mobilizon.Service.Auth.Authenticator
config :mobilizon, :ldap,
enabled: true,
host: "127.0.0.1",
port: 389,
ssl: false,
# sslopts: [],
tls: false,
# tlsopts: [],
base: "ou=users,dc=yunohost,dc=org",
uid: "uid",
require_bind_for_search: false,
bind_uid: nil,
bind_password: nil
config :mobilizon, Mobilizon.Web.Email.Mailer,
adapter: Swoosh.Adapters.SMTP,
relay: "127.0.0.1",
#hostname: "127.0.0.1",
# usually 25, 465 or 587
port: 587,
username: "mobilizon_notifs",
password: "xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx",
# can be `:always` or `:never`
tls: :always,
tls_options: [
versions: [:"tlsv1.2",:"tlsv1.3"],
verify: :verify_peer,
cacerts: :public_key.cacerts_get(),
server_name_indication: 'mobilizon.mydomain.tld',
depth: 99
ssl: false,
retries: 1,
# can be `true`
no_mx_lookups: false,
# can be `:always`. If your smtp relay requires authentication set it to `:always`.
auth: :always
config :mobilizon, Mobilizon.Web.Upload.Uploader.Local, uploads: "/home/yunohost.app/mobilizon/uploads"
config :web_push_encryption, :vapid_details,
subject: "mailto:me@mydomain.tld",
public_key: "xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx",
private_key: "xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx"
config :mobilizon, Mobilizon.Service.ResourceProviders,
types: [pad: :etherpad, calc: :ethercalc, visio: :jitsi],
providers: %{
etherpad: "https://pad.mydomain.tld/p/",
ethercalc: "https://lite.framacalc.org/",
jitsi: "https://visio.chapril.org/"
config :mobilizon, :external_resource_providers, %{
"https://https://cryptpad.mydomain.tld/drive/" => :cryptpad_drive,
"https://cryptpad.mydomain.tld/pad/" => :cryptpad_document,
"https://cryptpad.mydomain.tld/sheet/" => :cryptpad_tableur,
"https://cryptpad.mydomain.tld/slide/" => :cryptpad_presentation
