Is there a way to modify:
- « -hls_segment_type » from fmp4 to mpegts
- « -hls_segment_filename » to any filename with « %d »
- « -hls_flags single_file » remove
I try to create a addon for kodi with inputstream.adaptive ( GitHub - xbmc/inputstream.adaptive: kodi inputstream addon for several manifest types ) to view the hls streams with authentication… but this plugin is not able to stream audio for mp4/fragmented stuff.
(i try to modify ffmpeg-vod.js for the hls options, but this breaks other stuff in tslib.js / ffprobe-utils.js)
Breaking in what way? Errors would be helpful.
Maybe this helps a bit Allow for included streams in FragmentedSampleReader · Issue #343 · xbmc/inputstream.adaptive · GitHub
inputstream.adaptive cant play the included audio-stream from a mp4-fragmented container.
For a test i just created/transcoded the same videos like peertube does, the only change was « hls_segment_type mpegts » and it works great.
That’s completely different from there being errors in tslib.js/ffprobe-utils.js.
When you’re ready to post the errors you’re seeing I’d be happy to try troubleshooting this with you.
Here are the logs after changed -hls_segment_type in ffmpeg-vod.js and import a new video:
{"level":"info","message":"Handling WebTorrent transcoding job for 02aae006-f050-4442-bb87-d4c5520b4294.","label":"host.com:443","tags":["transcoding","02aae006-f050-4442-bb87-d4c5520b4294"],"timestamp":"2023-03-22T17:09:49.036Z"}
{"level":"info","message":"Creating torrent /home/peertube/storage/torrents/1083bcef-b4ab-43dc-a4b3-5db5ab02ac13-1080-hls.torrent.","label":"host.com:443","timestamp":"2023-03-22T17:09:55.941Z"}
[host.com:443] 2023-03-22 18:09:55.941 info: Creating torrent /home/peertube/storage/torrents/1083bcef-b4ab-43dc-a4b3-5db5ab02ac13-1080-hls.torrent.
{"err":{"stack":"TypeError: Cannot read properties of undefined (reading 'High')\n at /home/peertube/versions/peertube-v5.0.1/dist/server/helpers/ffmpeg/ffprobe-utils.js:43:56\n at Generator.next (<anonymous>)\n at fulfilled (/home/peertube/versions/peertube-v5.0.1/node_modules/tslib/tslib.js:115:62)","message":"Cannot read properties of undefined (reading 'High')"},"level":"info","message":"Cannot update playlist after file change. Maybe due to concurrent transcoding","label":"host.com:443","timestamp":"2023-03-22T17:09:56.112Z"}
[host.com:443] 2023-03-22 18:09:56.112 info: Cannot update playlist after file change. Maybe due to concurrent transcoding {
"err": {
"stack": "TypeError: Cannot read properties of undefined (reading 'High')\n at /home/peertube/versions/peertube-v5.0.1/dist/server/helpers/ffmpeg/ffprobe-utils.js:43:56\n at Generator.next (<anonymous>)\n at fulfilled (/home/peertube/versions/peertube-v5.0.1/node_modules/tslib/tslib.js:115:62)",
"message": "Cannot read properties of undefined (reading 'High')"
[host.com:443] 2023-03-22 18:09:56.113 info: HLS transcoding job for 02aae006-f050-4442-bb87-d4c5520b4294 ended.
Please post the code changes you’ve made and I’ll try to troubleshoot this for you.
--- dist/server/helpers/ffmpeg/ffmpeg-vod.js 2023-03-23 13:03:44.159246560 +0100
+++ /tmp/ffmpeg-vod.js 2023-03-28 22:02:01.879328313 +0200
@@ -102,7 +102,7 @@
.outputOption('-hls_list_size 0')
.outputOption('-hls_playlist_type vod')
.outputOption('-hls_segment_filename ' + outputPath)
- .outputOption('-hls_segment_type fmp4')
+ .outputOption('-hls_segment_type mpegts')
.outputOption('-f hls')
.outputOption('-hls_flags single_file');
but i guess, best option for this will be a « nativ » switch in der peertube-frontend to use fmp4 or mpegts
Works for me. No errors. I’m using the transcoding-profile-debug plugin.
The web player can’t play the videos though. VLC works when they’re downloaded.
transcoding-profile-debug with special flags? or just the plugin without using any encoder flags?
No special flags. I’m also using hls instead of webtorrent.
