I have two object storage buckets in use (with the same object storage provider). I would like to consolidate them into one bucket.
Problem: I can’t tell which bucket a video is stored in, using the web interface at least.
Question: Would a script with a SQL query be the answer?
There is a CLI tool to migrage object storage:
Use this script after you migrated to another object storage provider
Is this right for my case? I need to move videos from one bucket to another, and I need to know which ones to move.
Sorry, i don’t know. I never used object storage with Peertube.
You will have to wait someone more experienced on that.
(i guessed it would work, as there are --from and --to parameters)
