Does Peertube deinterlace?
When I upload interlaced videos Peertube doesn’t deinterlace them and I get a lot of combing in the video on peertube. I have 1000+ videos to add, many of which are interlaced and I don’t want to have to deinterlace them myself before uploading as that degrades the video quality. Is there a straightforward way of adding a deinterlace filter to the transcoding?
Do you have the ffmpeg command to deinterlace a video?
i’m also interested with an option to deinterlace an uploading video as i’ve a bunch of old videos to publish
we could use the bwdif filter in ffmpeg, like
-filter:v bwdif=mode=send_field:parity=auto:deint=all
Is there a way to apply the filter « manually » ?
i tried to pass the option using the transcoding-custom-quality plugin without success.
i simply added the line
in the builderVOD outputOptions in the main.js file but apparently it’s not the way to go (it would have been too simple), the instruction is ignored.
How can i pass the filter option to ffmeg ?
Via the plugin or any other way is fine
I’m surprised it doesn’t work. Did you choose the new transcoding profile in the admin config?
Yes, i’ve selected custom-quality in the admin config and i tried to encode with 2 different qualities (‹ Excellent › and ‹ low ›). ffmpeg seems to use the plugin as i have to different sizes for the same input test video
But the filter option seems to be ignored, the result is not deinterlaced. To be sure, I even tried with a syntax error in the filter line and the input video encodes anyway without any error as if the line was not read. Is it expected behavior ?
I may miss something but what ?
my modification in main.js of the plugin
 const builderVOD = (options) => {
    return {
      outputOptions: [
        `-r ${options.fps}`,
        `-crf ${store.crf}`,
        `-filter:v bwdif=mode=send_field:parity=auto:deint=all`
