"ERR max number of clients reached" on new instance
I’m giving a try on Peertube. I have installed a new VM and followed the docs.joinpeertube.org wiki to have the installation done.
So far, everything runs and I can access the main page from Firefox.
Still, the logs are filed with weird errors, given that the instance is brand new:
Mar  4 00:52:49 peertube peertube[55693]: [tube.example:443] 2024-03-04 00:52:49.724 ^[[31merror^[[39m: Error in job queue events videos-views-s
tats. {
Mar  4 00:52:49 peertube peertube[55693]:   "err": {
Mar  4 00:52:49 peertube peertube[55693]:     "stack": "ReplyError: ERR max number of clients reached\n    at Object.onceWrapper (node:events:631:28)\n
   at Socket.emit (node:events:529:35)\n    at TCPConnectWrap.afterConnect [as oncomplete] (node:net:1540:10)",
Mar  4 00:52:49 peertube peertube[55693]:     "message": "ERR max number of clients reached",
Mar  4 00:52:49 peertube peertube[55693]:     "command": {
Mar  4 00:52:49 peertube peertube[55693]:       "name": "info",
Mar  4 00:52:49 peertube peertube[55693]:       "args": []
Mar  4 00:52:49 peertube peertube[55693]:     }
Mar  4 00:52:49 peertube peertube[55693]: [tube.example:443] 2024-03-04 00:52:49.731 ^[[31merror^[[39m: Error in job worker generate-video-story
board. {
After searching for those errors on DuckDuckGo and GitHub Issues section, I’m landing here :slight_smile:
What do those errors mean?
Thanks
It’s a Redis error. Try to check your max users limit in Redis configuration: Redis client handling | Redis
Yep, that works. Default value was 96. I raised it to 1024. According to redis-cli info clients, you need at least 103.
Thanks a lot.
