Hello, quite a lot of errors are pouring due to an expired token, and requesting a new one. Is it possible
- How to increase the term of the token
- It is possible to somehow remove the appearance of errors if they do not affect the user experience
- Make sure that the token is requested in advance, for example)
There are quite a lot of such errors per user per day.
Thank you
{"err":{"stack":"invalid_token: Invalid token: access token has expired\n at AuthenticateHandler.validateAccessToken (/var/www/peertube/versions/peertube-v6.2.1/node_modules/@node-oauth/oauth2-server/lib/handlers/authenticate-handler.js:223:13)\n at AuthenticateHandler.handle (/var/www/peertube/versions/peertube-v6.2.1/node_modules/@node-oauth/oauth2-server/lib/handlers/authenticate-handler.js:71:32)\n at process.processTicksAndRejections (node:internal/process/task_queues:95:5)","message":"Invalid token: access token has expired","statusCode":401,"status":401,"code":401,"name":"invalid_token"},"level":"info","message":"Cannot authenticate.","label":"angeltales.angellive.ru:443","timestamp":"2024-08-15T21:42:47.700Z"}
{"tags":["http"],"level":"info","message":"95.153.0.0 - - [15/Aug/2024:21:42:47 +0000] \"POST /api/v1/videos/6b8abccd-a6b8-434a-bb43-437a803fde64/views HTTP/1.0\" 401 265 \"https://angeltales.angellive.ru/w/p/1LE2HroLXqbhSLUKrhmD4D?playlistPosition=14\" \"Mozilla/5.0 (Linux; Android 10; K) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/127.0.0.0 Mobile Safari/537.36\"","label":"angeltales.angellive.ru:443","timestamp":"2024-08-15T21:42:47.708Z"}
{"err":{"stack":"invalid_token: Invalid token: access token has expired\n at AuthenticateHandler.validateAccessToken (/var/www/peertube/versions/peertube-v6.2.1/node_modules/@node-oauth/oauth2-server/lib/handlers/authenticate-handler.js:223:13)\n at AuthenticateHandler.handle (/var/www/peertube/versions/peertube-v6.2.1/node_modules/@node-oauth/oauth2-server/lib/handlers/authenticate-handler.js:71:32)\n at process.processTicksAndRejections (node:internal/process/task_queues:95:5)","message":"Invalid token: access token has expired","statusCode":401,"status":401,"code":401,"name":"invalid_token"},"level":"info","message":"Cannot authenticate.","label":"angeltales.angellive.ru:443","timestamp":"2024-08-15T21:42:51.593Z"}
{"tags":["http"],"level":"info","message":"95.153.0.0 - - [15/Aug/2024:21:42:51 +0000] \"POST /api/v1/videos/6b8abccd-a6b8-434a-bb43-437a803fde64/views HTTP/1.0\" 401 265 \"https://angeltales.angellive.ru/w/p/1LE2HroLXqbhSLUKrhmD4D?playlistPosition=14\" \"Mozilla/5.0 (Linux; Android 10; K) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/127.0.0.0 Mobile Safari/537.36\"","label":"angeltales.angellive.ru:443","timestamp":"2024-08-15T21:42:51.594Z"}
{"err":{"stack":"invalid_token: Invalid token: access token has expired\n at AuthenticateHandler.validateAccessToken (/var/www/peertube/versions/peertube-v6.2.1/node_modules/@node-oauth/oauth2-server/lib/handlers/authenticate-handler.js:223:13)\n at AuthenticateHandler.handle (/var/www/peertube/versions/peertube-v6.2.1/node_modules/@node-oauth/oauth2-server/lib/handlers/authenticate-handler.js:71:32)\n at process.processTicksAndRejections (node:internal/process/task_queues:95:5)","message":"Invalid token: access token has expired","statusCode":401,"status":401,"code":401,"name":"invalid_token"},"level":"info","message":"Cannot authenticate.","label":"angeltales.angellive.ru:443","timestamp":"2024-08-15T21:42:52.026Z"}
{"tags":["http"],"level":"info","message":"95.153.0.0 - - [15/Aug/2024:21:42:52 +0000] \"GET /api/v1/videos/9e1cb836-509e-45f7-a6e2-ef58e419d098/captions HTTP/1.0\" 401 184 \"https://angeltales.angellive.ru/w/p/1LE2HroLXqbhSLUKrhmD4D?playlistPosition=15\" \"Mozilla/5.0 (Linux; Android 10; K) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/127.0.0.0 Mobile Safari/537.36\"","label":"angeltales.angellive.ru:443","timestamp":"2024-08-15T21:42:52.027Z"}
{"err":{"stack":"invalid_token: Invalid token: access token has expired\n at AuthenticateHandler.validateAccessToken (/var/www/peertube/versions/peertube-v6.2.1/node_modules/@node-oauth/oauth2-server/lib/handlers/authenticate-handler.js:223:13)\n at AuthenticateHandler.handle (/var/www/peertube/versions/peertube-v6.2.1/node_modules/@node-oauth/oauth2-server/lib/handlers/authenticate-handler.js:71:32)\n at process.processTicksAndRejections (node:internal/process/task_queues:95:5)","message":"Invalid token: access token has expired","statusCode":401,"status":401,"code":401,"name":"invalid_token"},"level":"info","message":"Cannot authenticate.","label":"angeltales.angellive.ru:443","timestamp":"2024-08-15T21:42:52.029Z"}
{"tags":["http"],"level":"info","message":"95.153.0.0 - - [15/Aug/2024:21:42:52 +0000] \"GET /api/v1/videos/9e1cb836-509e-45f7-a6e2-ef58e419d098/chapters HTTP/1.0\" 401 184 \"https://angeltales.angellive.ru/w/p/1LE2HroLXqbhSLUKrhmD4D?playlistPosition=15\" \"Mozilla/5.0 (Linux; Android 10; K) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/127.0.0.0 Mobile Safari/537.36\"","label":"angeltales.angellive.ru:443","timestamp":"2024-08-15T21:42:52.032Z"}
{"err":{"stack":"invalid_token: Invalid token: access token has expired\n at AuthenticateHandler.validateAccessToken (/var/www/peertube/versions/peertube-v6.2.1/node_modules/@node-oauth/oauth2-server/lib/handlers/authenticate-handler.js:223:13)\n at AuthenticateHandler.handle (/var/www/peertube/versions/peertube-v6.2.1/node_modules/@node-oauth/oauth2-server/lib/handlers/authenticate-handler.js:71:32)\n at process.processTicksAndRejections (node:internal/process/task_queues:95:5)","message":"Invalid token: access token has expired","statusCode":401,"status":401,"code":401,"name":"invalid_token"},"level":"info","message":"Cannot authenticate.","label":"angeltales.angellive.ru:443","timestamp":"2024-08-15T21:42:52.059Z"}
{"tags":["http"],"level":"info","message":"95.153.0.0 - - [15/Aug/2024:21:42:52 +0000] \"GET /api/v1/videos/9e1cb836-509e-45f7-a6e2-ef58e419d098 HTTP/1.0\" 401 266 \"https://angeltales.angellive.ru/w/p/1LE2HroLXqbhSLUKrhmD4D?playlistPosition=15\" \"Mozilla/5.0 (Linux; Android 10; K) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/127.0.0.0 Mobile Safari/537.36\"","label":"angeltales.angellive.ru:443","timestamp":"2024-08-15T21:42:52.061Z"}
{"err":{"stack":"invalid_token: Invalid token: access token has expired\n at AuthenticateHandler.validateAccessToken (/var/www/peertube/versions/peertube-v6.2.1/node_modules/@node-oauth/oauth2-server/lib/handlers/authenticate-handler.js:223:13)\n at AuthenticateHandler.handle (/var/www/peertube/versions/peertube-v6.2.1/node_modules/@node-oauth/oauth2-server/lib/handlers/authenticate-handler.js:71:32)\n at process.processTicksAndRejections (node:internal/process/task_queues:95:5)","message":"Invalid token: access token has expired","statusCode":401,"status":401,"code":401,"name":"invalid_token"},"level":"info","message":"Cannot authenticate.","label":"angeltales.angellive.ru:443","timestamp":"2024-08-15T21:42:52.101Z"}
{"tags":["http"],"level":"info","message":"95.153.0.0 - - [15/Aug/2024:21:42:52 +0000] \"GET /api/v1/videos/9e1cb836-509e-45f7-a6e2-ef58e419d098/storyboards HTTP/1.0\" 401 184 \"https://angeltales.angellive.ru/w/p/1LE2HroLXqbhSLUKrhmD4D?playlistPosition=15\" \"Mozilla/5.0 (Linux; Android 10; K) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/127.0.0.0 Mobile Safari/537.36\"","label":"angeltales.angellive.ru:443","timestamp":"2024-08-15T21:42:52.102Z"}
{"tags":["http"],"level":"info","message":"95.153.0.0 - - [15/Aug/2024:21:42:52 +0000] \"POST /api/v1/users/token HTTP/1.0\" 200 194 \"https://angeltales.angellive.ru/w/p/1LE2HroLXqbhSLUKrhmD4D?playlistPosition=15\" \"Mozilla/5.0 (Linux; Android 10; K) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/127.0.0.0 Mobile Safari/537.36\"","label":"angeltales.angellive.ru:443","timestamp":"2024-08-15T21:42:52.228Z"}
