Hello all,
I have deployed PeerTube on Docker and everything works perfectly but I can’t expose the PeerTube metrics from the container. I have enabled the metrics using the production.yaml and when I exec into the peertube container and do « curl localhost:9091/metrics » I get the metrics. But I can’t expose them outside of the container. I have forwarded the port in the docker-compose.yml with « - 9091:9091 » under « ports: », but still I can’t curl the metrics in the docker host.
Do you have any ideas on what I might miss?
Hey Chocobozzz,
thanks for the quick reply!
I changed the listening interface to the docker host (192.168.1.99) but it won’t spin the container.
In the docker logs I can see this:
Error: listen EADDRNOTAVAIL: address not available 192.168.1.99:9091
at Server.setupListenHandle [as _listen2] (node:net:1446:21)
at listenInCluster (node:net:1511:12)
at doListen (node:net:1660:7)
at wrappedLookupCallback (/app/node_modules/@opentelemetry/instrumentation-dns/build/src/instrumentation.js:129:29)
at processTicksAndRejections (node:internal/process/task_queues:84:21) {
"error": {
"stack": "Error: listen EADDRNOTAVAIL: address not available 192.168.1.99:9091\n at Server.setupListenHandle [as _listen2] (node:net:1446:21)\n at listenInCluster (node:net:1511:12)\n at doListen (node:net:1660:7)\n at wrappedLookupCallback (/app/node_modules/@opentelemetry/instrumentation-dns/build/src/instrumentation.js:129:29)\n at processTicksAndRejections (node:internal/process/task_queues:84:21)",
"message": "listen EADDRNOTAVAIL: address not available 192.168.1.99:9091",
"code": "EADDRNOTAVAIL",
"errno": -99,
"syscall": "listen",
"address": "192.168.1.99",
"port": 9091
I think it has to do with the peertube container having the default network with IP 172.18.0.x, so it can’t see the docker host network. Any ideas on how I can attach both networks to the container so it will see 172.18.0.x for the peertube webserver and 192.168.1.x for the metrics?
Update: I tried with 172.17.0.1 which is the IP of the docker host inside the containers, but still throws the same error. The funny thing is that this IP is ping-able from inside the container…
Ok, found it!
Have to change it to 0.0.0.0 since this is what is being forwarded with - "9091:9091"
under ports:
Now the metrics are exposed in the docker host.
