I had the wrong port number in my configs (444) when I first started peertube. Before I had federated with anyone, or even created any accounts or added any content, I fixed it and restarted peertube. Then I proceeded to use the instance. Things seem to work, including followers, but I see these failing activitypub-http-unicast
jobs. I think these are announcing new content to my followers…
I notice that there is just one field in there that has the wrong URL for my site:
"actor": "https://all.electric.kitchen:444/accounts/peertube",
That :444
shouldn’t be there - and I’m guessing it is what causes the failure? I’ve run update-host
and double checked that nothing in the config
tree has that old port number. And yet, these still happen. Is there something else, either in the DB or in some file that I should be fixing?
Full failing job example:
Job: 126
Type: activitypub-http-unicast
Processed on 12/30/23, 10:32:47.738 AM
Finished on 12/30/23, 10:32:47.995 AM
"uri": "https://post.lurk.org/inbox",
"signatureActorId": 1,
"body": {
"to": [
"https://www.w3.org/ns/activitystreams#Public",
"https://all.electric.kitchen/video-channels/works/followers",
"https://all.electric.kitchen/accounts/peertube/followers",
"https://all.electric.kitchen/accounts/ek/followers"
"cc": [],
"type": "Announce",
"id": "https://all.electric.kitchen/videos/watch/67bcf251-7091-4106-80ab-2ee4be156c33/announces/1",
"object": "https://all.electric.kitchen/videos/watch/67bcf251-7091-4106-80ab-2ee4be156c33"
"contextType": "Announce"
RequestError: write EPIPE
at ClientRequest.<anonymous> (file:///var/www/peertube/versions/peertube-v6.0.2/node_modules/got/dist/source/core/index.js:792:107)
at Object.onceWrapper (node:events:629:26)
at ClientRequest.emit (node:events:526:35)
at TLSSocket.socketErrorListener (node:_http_client:495:9)
at TLSSocket.emit (node:events:514:28)
at emitErrorNT (node:internal/streams/destroy:151:8)
at emitErrorCloseNT (node:internal/streams/destroy:116:3)
at process.processTicksAndRejections (node:internal/process/task_queues:82:21)
at WriteWrap.onWriteComplete [as oncomplete] (node:internal/stream_base_commons:94:16)
at writevGeneric (node:internal/stream_base_commons:138:26)
at Socket._writeGeneric (node:net:950:11)
at Socket._writev (node:net:959:8)
at doWrite (node:internal/streams/writable:580:12)
at clearBuffer (node:internal/streams/writable:757:5)
at Writable.uncork (node:internal/streams/writable:515:7)
at ClientRequest._flushOutput (node:_http_outgoing:1151:10)
at ClientRequest._flush (node:_http_outgoing:1120:22)
at onSocketNT (node:_http_client:898:9)
