Federation IPv6
Describe the current behavior
Peertube 7.x does not federate with IPv4 only instances. IPv6 instances are working. NAT64 activated. Docker/k3s installation.
Steps to reproduce
ACTIVITYPUB-HTTP-UNICAST - FAILED
Describe the expected behavior
Job: 1
Type: activitypub-http-unicast
Processed on 23.12.24, 10:03:55,795
Finished on 23.12.24, 10:03:57,298
`{` ` "uri": "https://tilvids.com/video-channels/thelinuxexperiment_channel/inbox",` ` "signatureActorId": 1,` ` "body": {` ` "type": "Follow",` ` "id": "https://peertube.xxxx.xxx/accounts/peertube/follows/192",` ` "actor": "https://peertube.xxxx.xxx/accounts/peertube",` ` "object": "https://tilvids.com/video-channels/thelinuxexperiment_channel"` ` },` ` "contextType": "Follow"` `}`
HTTPError: Response code 403 (Forbidden)
at Request.<anonymous> (file:///app/node_modules/got/dist/source/as-promise/index.js:86:42)
at Object.onceWrapper (node:events:632:26)
at Request.emit (node:events:529:35)
at Request._onResponseBase (file:///app/node_modules/got/dist/source/core/index.js:726:22)
at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
at async Request._onResponse (file:///app/node_modules/got/dist/source/core/index.js:768:13)
Job: 37
Processed on 28.12.24, 03:06:20,401
Finished on 28.12.24, 03:06:27,421
`{` ` "uri": "https://tilvids.com/video-channels/thelinuxexperiment_channel/inbox",` ` "signatureActorId": 6,` ` "body": {` ` "type": "Follow",` ` "id": "https://peertube.xxxx.xxx/accounts/benutzer/follows/192",` ` "actor": "https://peertube.xxxx.xxx/accounts/benutzer",` ` "object": "https://tilvids.com/video-channels/thelinuxexperiment_channel"` ` },` ` "contextType": "Follow"` `}`
RequestError: Timeout awaiting 'request' for 7000ms
at ClientRequest.<anonymous> (file:///app/node_modules/got/dist/source/core/index.js:792:61)
at ClientRequest.emit (node:events:529:35)
at TLSSocket.socketErrorListener (node:_http_client:501:9)
at TLSSocket.emit (node:events:517:28)
at emitErrorNT (node:internal/streams/destroy:151:8)
at emitErrorCloseNT (node:internal/streams/destroy:116:3)
at process.processTicksAndRejections (node:internal/process/task_queues:82:21)
at Timeout.timeoutHandler [as _onTimeout] (file:///app/node_modules/got/dist/source/core/timed-out.js:42:25)
at listOnTimeout (node:internal/timers:571:11)
at process.processTimers (node:internal/timers:512:7)
Job: 34
Type: activitypub-http-fetcher
Processed on 28.12.24, 03:06:27,878
Finished on 28.12.24, 03:06:36,830
"uri": "https://tilvids.com/video-channels/thelinuxexperiment_channel/outbox",
"type": "activity"
Additional information
Peertube 7.x
Mastodon
Mastodon needs the following configuration: ALLOWED_PRIVATE_ADDRESSES: 64:ff9b::/96 to allow NAT64…
Works fine for me on 7.0.1.
Thanks @FrenzyBiscuit !
It works now!
  1. deleted every federation
  2. add every federation again
