Hi !
I just started Mobilizon recently. I’m a simple user on a particular instance.
Today I missed the Contribatelier which is on another instance than mine. So I intended to follow the group and be aware of the next ones.
Apparently you can subscribe to the group but not follow it. Is this a normal behaviour of Mobilizon ? Does my instance not follow the mobilizon.fr instance ? Is it a wannabe feature ?
Thanks for your help.
PS : Side question, how do I know which instances are federated by mine ?
