Has anyone been able to setup and use garage (https://garagehq.deuxfleurs.fr/) as object storage for their instance? I have some questions about the CORS settings described here. Apps (Nextcloud, Peertube...) | Garage HQ
How am I supposed to set up those two aws endpoint commands? aws --endpoint http://s3.garage.localhost s3api put-bucket-cors --bucket peertube-playlists --cors-configuration $CORS
Do I need to input my instance URL here?
Don’t know if you’re still working on this, but I got it working in the last couple days after beating my head against it for a while
This was on ubuntu
- installed AWS with apt install
- run AWS configure and supply it with the PeerTube key information, garage default region name, and json default output file
- not sure if this was needed but it was part of my troubleshooting before I finally beat it. created .awsrc with nano ~/.awsrc and populated it with
export AWS_ACCESS_KEY_ID=[fill in your value] # put your Key ID here
export AWS_SECRET_ACCESS_KEY=[fill in your value] # put your Secret key here
export AWS_DEFAULT_REGION='garage'
export AWS_ENDPOINT_URL='http://[localhost or DNS address of Garage server]:3900'
aws --version
- add :3900 to the address of the Garage server in the cors command from the Garage supplied PeerTube instructions
export CORS='{"CORSRules":[{"AllowedHeaders":["*"],"AllowedMethods":["GET"],"AllowedOrigins":["*"]}]}'
aws --endpoint http://[localhost or DNS address of Garage server]:3900 s3api put-bucket-cors --bucket peertube-playlists --cors-configuration $CORS
aws --endpoint http://[localhost or DNS address of Garage server]:3900 s3api put-bucket-cors --bucket peertube-videos --cors-configuration $CORS
That finally got the CORS configured properly for me.
I will take another shot at setting this up. Thanks for the pointers @errhead.
