Hey everyone,
I’m quite new to the Frama community and I seem to be unable to plot data from a Framacalc. Can anyone help me ?
Thanks in advance !
Hey everyone,
Thanks in advance !
Hello
Well, I guess you meant: having a charts graphs with the temperature progression during timeline upon the calc sheet.
I think we are not able to put the charts on the sheet directly or easily.
But to make some sort of charts, you should
This is, in my opinion, a very limited charts application. I don’t find any maneer to apply headers or something similar.
Hope this will help you a few.
That’s precisely what I repeatedly tried to do, without success : the X and Y min and max value refuse to change… Did you try it yourself on my sheet ?
Thanks for your answer anyway !
I found some explanations here: https://github.com/audreyt/ethercalc/issues/356
to create a graph
2 years ago, framacalc.org had a bug #339 which needed to be updated but it seems ok now.
Thanks, that works. Does anyone know how to label the axes though ?
