Help needed on Upgrade from 3.2.1 to 7.3.0
I need to upgrade a very old Peertube installation 3.2.1 on Debian 12 (no Docker) to the latest 7.3.0.
I tried it step by step to 4.x or 5.x, but always there were missing dependencies :frowning:
I now updated directly to 7.3, run the 6.3 migration script and modified the production.yaml.
Unfortnately PT won’t start and I get the following log entries, but no idea what the cause could be:
Sep 26 12:22:05 example-server peertube[92403]: [tube.example.net:443] 2025-09-26 12:22:05.214 info: HTTP server listening on localhost:9000
Sep 26 12:22:05 example-server peertube[92403]: [tube.example.net:443] 2025-09-26 12:22:05.214 info: Web server: https://tube.example.net
Sep 26 12:22:05 example-server peertube[92403]: [tube.example.net:443] 2025-09-26 12:22:05.228 debug: Executed SQL request - Executing (default): SELECT "Applicat>
Sep 26 12:22:05 example-server peertube[92403]: [tube.example.net:443] 2025-09-26 12:22:05.241 debug: Executed SQL request - Executing (default): UPDATE "applicat>
Sep 26 12:22:05 example-server peertube[92403]: Error fetching languages: SyntaxError: Unexpected token '<', "<html>
Sep 26 12:22:05 example-server peertube[92403]: <h"... is not valid JSON
Sep 26 12:22:05 example-server peertube[92403]:     at JSON.parse (<anonymous>)
Sep 26 12:22:05 example-server peertube[92403]:     at parseJSONFromBytes (node:internal/deps/undici/undici:5738:19)
Sep 26 12:22:05 example-server peertube[92403]:     at successSteps (node:internal/deps/undici/undici:5719:27)
Sep 26 12:22:05 example-server peertube[92403]:     at fullyReadBody (node:internal/deps/undici/undici:4609:9)
Sep 26 12:22:05 example-server peertube[92403]:     at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
Sep 26 12:22:05 example-server peertube[92403]:     at async consumeBody (node:internal/deps/undici/undici:5728:7)
PT does not listen on 900 ether
Any help is highly appreciated.
Found the issue:
in Nginx I had to change “127.0.0.1” in “localhost” in the following section:
upstream backend {
server localhost:9000;
