[HELP] Podman, Peertube, AMD VAAPI
hey all!
for the life of me, i cannot get VAAPI hardware accelerated encoding to work. i always get this error:
Error: ffmpeg exited with code 234: Device creation failed: -22.
Failed to set value ‹ /dev/dri/renderD128 › for option ‹ vaapi_device ›: Invalid argument
Error parsing global options: Invalid argument`
at ChildProcess.<anonymous> (/app/node_modules/fluent-ffmpeg/lib/processor.js:180:22)
at ChildProcess.emit (node:events:524:28)
at ChildProcess._handle.onexit (node:internal/child_process:293:12)
  • AMD Radeon RX 9060 XT
  • i have mesa-va-drivers and mesa-libgallium installed from backports.
  • the container is rootful.
  • /dev/dri is mapped
  • the render group id matches between host and container.
  • SELinux is set to allow containers access to devices.
no joy.
vainfo
error: XDG_RUNTIME_DIR is invalid or not set in the environment.
error: can’t connect to X server!
libva info: VA-API version 1.17.0
libva info: Trying to open /usr/lib/x86_64-linux-gnu/dri/radeonsi_drv_video.so
libva info: Found init function __vaDriverInit_1_17
amdgpu: os_same_file_description couldn’t determine if two DRM fds reference the same file description.
If they do, bad things may happen!
libva info: va_openDriver() returns 0
vainfo: VA-API version: 1.17 (libva 2.12.0)
vainfo: Driver version: Mesa Gallium driver 25.0.4-1~bpo12+1 for AMD Radeon Graphics (radeonsi, gfx1200, ACO, DRM 3.63, 6.15.4-1-default)
vainfo: Supported profile and entrypoints
VAProfileH264ConstrainedBaseline: VAEntrypointVLD
VAProfileH264ConstrainedBaseline: VAEntrypointEncSlice
VAProfileH264Main : VAEntrypointVLD
VAProfileH264Main : VAEntrypointEncSlice
VAProfileH264High : VAEntrypointVLD
VAProfileH264High : VAEntrypointEncSlice
VAProfileHEVCMain : VAEntrypointVLD
VAProfileHEVCMain : VAEntrypointEncSlice
VAProfileHEVCMain10 : VAEntrypointVLD
VAProfileHEVCMain10 : VAEntrypointEncSlice
VAProfileJPEGBaseline : VAEntrypointVLD
VAProfileVP9Profile0 : VAEntrypointVLD
VAProfileVP9Profile2 : VAEntrypointVLD
VAProfileAV1Profile0 : VAEntrypointVLD
VAProfileAV1Profile0 : VAEntrypointEncSlice
VAProfileNone : VAEntrypointVideoProc
i’ve also tried updating the packages from trixie and sid, and installing the firmware-linux-nonfree.
i’ve tried disabling SELinux. i’ve tried making the container permissive.
no change.
any help is appreciated! thank you!
Solved:
