Hide links
Hi all,
Is there any way to hide any of the links present in the image capture (API, etc)?
Screenshot_20240719_112309
2.- What about the « About » link? For example, the « About » link shows some sensitive information (PeerTube version, if there is something enabled or not, etc) that no one should see (only the platform administrator).
Thanks
You can hide it using CSS or a peertube plugin.
Hi @Chocobozzz ,
Sorry to bother but do you know the specific path for this and the name of the plugin?
Thank you very much
