Hi. I am trying to get list of comments with a link via API.
Passing http://
and https://
works, but not for URL with no protocol.
For example, if you comment test.com
, the text will be hyperlinked.
So, how do I get them via API?
I am trying to do some auto-moderation which deletes comment based on certain rules.
Thank you.
« Linkification » is done directly in the client, not on the server. You may want to add a regex in your auto moderation tool to detect these links
Is it possible to define how many latest comments I can get via the API?
I can only retrieve like 15 comments at once.
Yes using count
: PeerTube
I see. I was looking at this instead and there is no count
parameter. But it works anyway, so thanks.
