There is a way to decrease the download speed for videos?
To avoid high consumption of bandwidth?
Thanks a lot!
Thanks a lot!
In the nginx configuration file, https://github.com/Chocobozzz/PeerTube/blob/develop/support/nginx/peertube , search for «rate» and you will find several settings.
And of course, you can disable high resolutions.
Thanks a lot for the quick reply!
I would like to allow premium users to download fast and none premium users to download slow,
you think this is possible, what would you do to achieve this?
What would I do? Definitively not something like this. That’s the best way to give a bad experience to people, and keep them away from your services.
I totally agree but I need to achieve this function, you have any suggestion ?
