Hello, I am wondering How I can host jitsi and Peertube on the same instance my machine says port 80 is in use by another service (used by jitsi) can I change the ports used to allow both to co-exist?
It should not be a problem. Both Peertube and Jitsi use nginx. I have both on my server.
Unless you used docker for one of them? In that case, I don’t know how it works.
I used 1 machine, and I got an issue with journal -xe so I uninstalled it
What issue? What have you uninstalled? Please be more specific.
What is your OS? Which installation procedure did you follow for Peertube? For Jitsi? …
the jitsi installation has been there for months, I Just added peertube.
Ubuntu 20.04 Server
Official
Official,
