I already have pleroma running on this server, would it be possible to use the same accounts for peertube and pleroma?
I have a peertube instance running on this server and i was wondering if i could disable registration for the peertube instance, and allow login using the pleroma instance’s account credentials?
No sorry you can’t share accounts between peertube and pleroma. They are different software.
ok , thanks for reply :slight_smile: ,
i was just wondering because. peertube was using postgres and pleroma was using postgres , perhaps my peoples wouldn’t need 2 seperate accounts.
later i’ll be setting it up , got the nginx config and sub-domain already setup , i just need to get the actually program running.
