where can i find information about video of peertube instances
- minimum and maximum resolution size
- maximum file size - uploads
- maximum storage (ex: 1gb or 2gb)
- post character limit
- markdown or text support of post
Hi!
You can use the REST API to get informations about the instance config.
All API endpoints can be found in the documentation: PeerTube REST API documentation
The endpoint which interests us here is this one: PeerTube REST API documentation
You’ll find there enabled resolutions.
Exemple of usage: https://aperi.tube/api/v1/config
Unfortunately, I don’t think endpoints exist for other informations you are looking for.
@Booteille wow… it is wonderful. half of the issue is resolved. now i have to find docs in plain language about various terms used in config file.
ex: max size: 20971520 bits or bytes or kilobytes on https://peertube.touhoppai.moe/api/v1/config
