Dear all, newbie here and I am facing some issue with the installation of Peertube using Docker. There is an issue with the Bind Mount, which I assume is the creating of various folders facing issue. Anyone facing this problem?
Siangloon@LauCloud:/volume1/docker/peertube$ sudo docker-compose up
Attaching to certbot, peertube-peertube-1, peertube-postfix-1, peertube-postgres-1, peertube-redis-1, peertube-webserver-1
Error response from daemon: Bind mount failed: '/volume1/docker/peertube/docker-volume/redis' does not exists
