Instance follow playlist from another instance
Is it possible to follow a playlist from another instance ?
I see I can do it for a channel, but not for a playlist.
A channel would be ok if I could set it as « unlisted » in my instance.
What I’m trying to achieve is :
  • have my videos organized on my instance with specific playlists and channels ;
  • have a few other specific channels or playlists that are invisible on my instance, and are only used to « share » video with other instances (the « collections » of videos will be different from the one created with the channel/playlist of my instance, so I can’t just share this « local » one.)
I hope this is clear :slight_smile:
Thanks for your help.
No sorry you can’t follow a playlist
Hi Chocobozzz,
Thanks for your quick answer.
Do you think it could be implemented in a futur version ? (or according to you, this is’nt possible for other reasons in the way of the « folowing process » works ?)
Or do you think that the goal I’m trying to achieve would be possible with a plugin ?
Because I have think a little more about using channels, and it isn’t a solution because I can’t add the same video to multiple channels (and as already mentionned, I can’t set the channel visibility).
Best regards, Eric.
+1
I suggested in this topic to follow videos with a specific tag or category.
