After consideration from my previous topic, I actually decided to migrate my instance to a different VPS (actually having great specs with 6 vCPU’s, 8 GB RAM, 700 GB NVMe storage for just €15 a month, have a look at strato.nl if you’re interested).
So, I migrated following the migration documentation and the server is up and has all data. Thing is: I can’t login. I get the error: « Invalid client: client is invalid ».
Looking around, I can’t find a terrible lot that fits my situation. It’s a non-docker install and the instance has identical configuration (I scp’ed it all) for /var/www/peertube/config, /etc/nginx/sites-enabled, /etc/letsencrypt, and /etc/systemd/system/peertube.service
Am I forgetting anything? What could be wrong?
