I want to summarize the problem I encounter with peertube during a 24-hour live streaming of an IP cam.
The IP cameras are from research centers that monitor Italian volcanoes and/or the Venice lagoon.
The ffmpeg code I use is the following:
~/…/…/usr/local/bin/ffmpeg -re -rtsp_transport tcp -i rtsp://xxx.xxx.xxx.xxx:7447/vSbhbI6tpvCkc821
-c:v libx264 -preset ultrafast -b:v 2500k -maxrate 3000k -bufsize 3000k -g 60
-f flv -flvflags no_duration_filesize
-reconnect 1 -reconnect_streamed 1 -reconnect_delay_max 4
-err_detect explode
-recovery_wait_time 1 rtmp://garr.tv:1935/live/e215e9a5-9dae-45cd-81ff-5be870213de9
A cron code checks the process every 20 min:
*/20 * * * * cd ~/…/…/usr/local/bin && ./riavvia-tutto.sh >/dev/null 2>&1
the verification code is this:
processes=(« garrtv-ptfeast.sh »)
for process in « ${processes[@]} »; do
ESEC=$(pgrep -fl « $process » | grep -v « grep » | wc -l)
if [ "$ESEC" -eq 0 ]; then
~/../../usr/local/bin/"$process" &
echo "Il processo $process è stato avviato"
else
echo "Il processo $process è già attivo"
fi
done
everything works, up to a certain point where the live instance of peertube seems to reject the incoming stream:
warn[14/12/2023, 19:28:34] Video 3707ff0c-bf7b-4733-8529-8808c97013aa has already a live session. Refusing stream 2c443728-24fd-4953-b19b-ae31a8f74e53. { « tags »: [ « live », « NVBA1Z20 », « 3707ff0c-bf7b-4733-8529-8808c97013aa » ] }
when this happens, I also tried to launch streaming with OBS, but even in this case I get the same error.
do you have any ideas regarding this problem?
This is an important activity for our research centers. IP cams often use radio links, being found in uninhabited and remote areas. In the case of the Venice lagoon the cams are placed on marine platforms and in the case of volcanoes they are in areas not served by the internet
Etna - GARR.tv - Thermal cameras in Etna Vulcano
Live test ptfeast 2 - GARR.tv - Camera in Venezia Lagoon
CNR ISMAR sette martiri - GARR.tv - Camera in Venezia
can you help me?
