Hi folks - I’m aware that sepia has a neat search tool, Sepiasearch.
However, when carrying out a search, I realised that some results linked to a channel on an instance that was down. Is there a way to filter out searches, instead of filtering a search to only include results from a specific channel?
Here’s what I see in sepia search:
I’ve tried a few variants of common search syntax like « -ThatChannel » to remove say… ThatChannel from results, but I’m not having much luck - is there a syntax I should be using, or would I need to open an issue on the underlying codebase?
I’m aware of this result here that suggests creating an issue, but it looks like it’s from 2019:
Before I filed an issue, it seemed worth asking here first.
Merci!
