Issues when upgrading from Peertube 2.4 to 3.1
I am using docker compose to run Peertube (with the yml file). When I follow the update procedure from the help file, which is to delete the old conatiners and pull the new ones, I get the following error from the Postgres docker container:
PostgreSQL Database directory appears to contain a database; Skipping initialization
2021-04-18 15:46:25.137 UTC [1] FATAL:  database files are incompatible with server
2021-04-18 15:46:25.137 UTC [1] DETAIL:  The data directory was initialized by PostgreSQL version 10, which is not compatible with this version 13.2.
I guess I need to update the SQL database somehow.
Where can I find the procedures for that?
Thanks!
hi @redspace,
Something like https://jlelse.blog/dev/migrate-postgres-docker will help you there.
Thank you! I was able to update it with the tutorial.
The only thing that did not work was the psql -U peertubeuser < pgdump.
I had to add -d parameter → psql -U peertubeuser -d peertube < /var/lib/postgresql/data/pgdump
I didn’t work for me but using docker-postgres-upgrade while making sure users are correct https://github.com/tianon/docker-postgres-upgrade/issues/10#issuecomment-541285270 and pg_hba.conf exists https://github.com/tianon/docker-postgres-upgrade/issues/16 did.
