- From Docker - Mobilizon
You can setup advanced configuration through the config.exs Elixir file. To get a file, docker cp mobilizon:/etc/mobilizon/config.exs .
Because the image will have been set up by docker-compose, this command will not work (the actual image name is docker-mobilizon_mobilizon_1
- In the
docker-compose.yml
file, there are the following lines:
# - ${PWD}/config.exs:/etc/mobilizon/config.exs:ro
# - ${PWD}/GeoLite2-City.mmdb:/var/lib/mobilizon/geo_db/GeoLite2-City.mmdb
The environment variable ${PWD}
is not set - in both cases it should be replaced with .
