I am from a legal observer group in the UK that is looking for a Mobilizon instance that is hosted in Switzerland (i.e. beyond UK and EU jurisdiction) that is suitable for English speaking users.
Using the https://instances.joinmobilizon.org (and scrolling to the right side of the table you can view the country of the instance server¹). From what I can see there’s currently only one instance that looks hosted in Switzerland with open registrations: https://events.cudy.org
¹ False positives can happen, server IPs are geolocated using free IP location databases.
I had noticed the Swiss instance that you mention, but noticed also that it is a German language instance, which would make it much less useable for English speakers.
I have had only the most superficial look at https://events.cudy.org, and can’t see an option there to change language from the German default.
Is there a way to change the language setting in Mobilizon, or will my search for an English language Swiss instance be fruitless, if this is my only option?
