Still having these issues, mainly of the permanent stream keys that stop working. Could anyone help me out?
The streams start out fine, but after a while the logs say: unknown live video with key: *****, here are the debug logs for this moment.
It happens with several permanent live streams.
debug[6-1-2025, 10:15:51] Adding local viewer to video viewers counter 0ca80e84-3bff-4ba5-8bbe-1c885652bf53.
"tags": [
"views",
"0ca80e84-3bff-4ba5-8bbe-1c885652bf53"
debug[6-1-2025, 10:15:51] Adding local view to video 0ca80e84-3bff-4ba5-8bbe-1c885652bf53.
"watchTime": 3279,
"tags": [
"views",
info[6-1-2025, 10:15:51] 84.26.57.145 - - [06/Jan/2025:09:15:51 +0000] "POST /api/v1/videos/0ca80e84-3bff-4ba5-8bbe-1c885652bf53/views HTTP/1.0" 204 - "https://app.demixthuis.nl/w/2yDvFmq5cXi3Ck4GJdz65g" "Mozilla/5.0 (Linux; Android 10; K) AppleWebKit/537.36 (KHTML, like Gecko) SamsungBrowser/27.0 Chrome/125.0.0.0 Mobile Safari/537.36"
"tags": [
"http"
debug[6-1-2025, 10:15:51] Live add handler of TS file /var/www/peertube/storage/streaming-playlists/hls/76389860-04dd-49e5-9e32-d624628ce507/1-000053.ts.
"tags": [
"live",
"OFGOVB3Q",
"76389860-04dd-49e5-9e32-d624628ce507"
debug[6-1-2025, 10:15:51] Adding live sha segment /var/www/peertube/storage/streaming-playlists/hls/76389860-04dd-49e5-9e32-d624628ce507/1-000052.ts.
"tags": [
"live",
debug[6-1-2025, 10:15:51] Live add handler of TS file /var/www/peertube/storage/streaming-playlists/hls/76389860-04dd-49e5-9e32-d624628ce507/2-000053.ts.
"tags": [
"live",
"OFGOVB3Q",
debug[6-1-2025, 10:15:51] Live add handler of TS file /var/www/peertube/storage/streaming-playlists/hls/76389860-04dd-49e5-9e32-d624628ce507/3-000053.ts.
"tags": [
"live",
"OFGOVB3Q",
debug[6-1-2025, 10:15:51] Adding live sha segment /var/www/peertube/storage/streaming-playlists/hls/76389860-04dd-49e5-9e32-d624628ce507/2-000052.ts.
"tags": [
"live",
debug[6-1-2025, 10:15:51] Adding live sha segment /var/www/peertube/storage/streaming-playlists/hls/76389860-04dd-49e5-9e32-d624628ce507/3-000052.ts.
"tags": [
"live",
debug[6-1-2025, 10:15:51] Writing segment sha JSON /var/www/peertube/storage/streaming-playlists/hls/76389860-04dd-49e5-9e32-d624628ce507/segments-sha256.json of 76389860-04dd-49e5-9e32-d624628ce507 on disk.
"tags": [
"live",
"tags": [
"live",
"tags": [
"live",
debug[6-1-2025, 10:15:51] Live add handler of TS file /var/www/peertube/storage/streaming-playlists/hls/76389860-04dd-49e5-9e32-d624628ce507/0-000053.ts.
"tags": [
"live",
"OFGOVB3Q",
debug[6-1-2025, 10:15:51] Adding live sha segment /var/www/peertube/storage/streaming-playlists/hls/76389860-04dd-49e5-9e32-d624628ce507/0-000052.ts.
"tags": [
"live",
"tags": [
"live",
debug[6-1-2025, 10:15:51] Live delete handler of TS file /var/www/peertube/storage/streaming-playlists/hls/76389860-04dd-49e5-9e32-d624628ce507/1-000037.ts.
"tags": [
"live",
"OFGOVB3Q",
debug[6-1-2025, 10:15:51] Removing live sha segment /var/www/peertube/storage/streaming-playlists/hls/76389860-04dd-49e5-9e32-d624628ce507/1-000037.ts.
"tags": [
"live",
"tags": [
"live",
debug[6-1-2025, 10:15:51] Live delete handler of TS file /var/www/peertube/storage/streaming-playlists/hls/76389860-04dd-49e5-9e32-d624628ce507/2-000037.ts.
"tags": [
"live",
"OFGOVB3Q",
debug[6-1-2025, 10:15:51] Removing live sha segment /var/www/peertube/storage/streaming-playlists/hls/76389860-04dd-49e5-9e32-d624628ce507/2-000037.ts.
"tags": [
"live",
debug[6-1-2025, 10:15:51] Live delete handler of TS file /var/www/peertube/storage/streaming-playlists/hls/76389860-04dd-49e5-9e32-d624628ce507/3-000037.ts.
"tags": [
"live",
"OFGOVB3Q",
debug[6-1-2025, 10:15:51] Removing live sha segment /var/www/peertube/storage/streaming-playlists/hls/76389860-04dd-49e5-9e32-d624628ce507/3-000037.ts.
"tags": [
"live",
debug[6-1-2025, 10:15:51] Live delete handler of TS file /var/www/peertube/storage/streaming-playlists/hls/76389860-04dd-49e5-9e32-d624628ce507/0-000037.ts.
"tags": [
"live",
"OFGOVB3Q",
debug[6-1-2025, 10:15:51] Removing live sha segment /var/www/peertube/storage/streaming-playlists/hls/76389860-04dd-49e5-9e32-d624628ce507/0-000037.ts.
"tags": [
"live",
"tags": [
"live",
"tags": [
"live",
"tags": [
"live",
debug[6-1-2025, 10:15:52] Checking POST - /api/v1/videos/fd775a98-79d3-4e50-a1f2-b3c7627f61b9/views parameters
"body": {
"currentTime": 67,
"sessionId": "CK8dvLr3oPrfvhenpO8HOEUlZQnCF9YL"
"params": {
"videoId": "fd775a98-79d3-4e50-a1f2-b3c7627f61b9"
"query": {},
"tags": [
"views"
debug[6-1-2025, 10:15:52] Model cache hit for load-video-immutable-id -> fd775a98-79d3-4e50-a1f2-b3c7627f61b9.
