I had a working peertube instance and i did upgrade OS from bullseye to bookworm.
Once done login with openid-connect was not possible and no login button was proposed for.
What i found out is : if external authentication service is not contactable at peertube restart then authentication plugin is seen as non existing.
So first check if url of openid-connect is contactable from peertube server and fix it, then restart peertube.
This might be a valuable informaton for people struggling with such issue.
– my life –
After a review of my configuration, and logs i found out that my openid authentication url was now resolved in ipV6 (and dns address) instead of ipV4, and since this goes through a freebox where i explictly disabled ipv6 it didn’t connect to openid server at peertube restart.
I modified my /etc/host to use a local link ipv6 address since i operate openid server too, and that working after a peertube restart
– my life –
